Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1662 Discussions
Can OpenCL now run Intel OneAPI devcloud?
dyedd
In Past solutions ,This method cannot be used anymore because there is no clang compiler.
clang ocl_vecadd.c -o ocl_vecadd -lOpenCL -lm -I/opt/intel/inteloneapi/compiler/latest/linux/include/sycl/ && ./ocl_vecadd
 I have tried to replace clang with icpx, but I cannot obtain the result. The following error is reported:
/usr/bin/ld: /tmp/icpx-b9b022/gpu_sample-4f1f6b.o: in function `main':
gpu_sample.cpp:(.text+0xc9): undefined reference to `clGetPlatformIDs'
/usr/bin/ld: gpu_sample.cpp:(.text+0xea): undefined reference to `clGetPlatformIDs'
/usr/bin/ld: gpu_sample.cpp:(.text+0x109): undefined reference to `clGetDeviceIDs'
/usr/bin/ld: gpu_sample.cpp:(.text+0x139): undefined reference to `clGetDeviceIDs'
/usr/bin/ld: gpu_sample.cpp:(.text+0x15d): undefined reference to `clCreateContext'
/usr/bin/ld: gpu_sample.cpp:(.text+0x171): undefined reference to `clCreateCommandQueue'
/usr/bin/ld: gpu_sample.cpp:(.text+0x18b): undefined reference to `clCreateBuffer'
/usr/bin/ld: gpu_sample.cpp:(.text+0x1ac): undefined reference to `clCreateBuffer'
/usr/bin/ld: gpu_sample.cpp:(.text+0x1d5): undefined reference to `clCreateBuffer'
/usr/bin/ld: gpu_sample.cpp:(.text+0x208): undefined reference to `clEnqueueWriteBuffer'
/usr/bin/ld: gpu_sample.cpp:(.text+0x235): undefined reference to `clEnqueueWriteBuffer'
/usr/bin/ld: gpu_sample.cpp:(.text+0x25a): undefined reference to `clCreateProgramWithSource'
/usr/bin/ld: gpu_sample.cpp:(.text+0x276): undefined reference to `clBuildProgram'
/usr/bin/ld: gpu_sample.cpp:(.text+0x28f): undefined reference to `clCreateKernel'
/usr/bin/ld: gpu_sample.cpp:(.text+0x2a6): undefined reference to `clSetKernelArg'
/usr/bin/ld: gpu_sample.cpp:(.text+0x2c1): undefined reference to `clSetKernelArg'
/usr/bin/ld: gpu_sample.cpp:(.text+0x2dc): undefined reference to `clSetKernelArg'
/usr/bin/ld: gpu_sample.cpp:(.text+0x317): undefined reference to `clEnqueueNDRangeKernel'
/usr/bin/ld: gpu_sample.cpp:(.text+0x347): undefined reference to `clEnqueueReadBuffer'
/usr/bin/ld: gpu_sample.cpp:(.text+0x383): undefined reference to `clReleaseKernel'
/usr/bin/ld: gpu_sample.cpp:(.text+0x38d): undefined reference to `clReleaseProgram'
/usr/bin/ld: gpu_sample.cpp:(.text+0x395): undefined reference to `clReleaseCommandQueue'
/usr/bin/ld: gpu_sample.cpp:(.text+0x39f): undefined reference to `clReleaseMemObject'
/usr/bin/ld: gpu_sample.cpp:(.text+0x3a9): undefined reference to `clReleaseMemObject'
/usr/bin/ld: gpu_sample.cpp:(.text+0x3b3): undefined reference to `clReleaseMemObject'
/usr/bin/ld: gpu_sample.cpp:(.text+0x3bd): undefined reference to `clReleaseContext'
icpx: error: linker command failed with exit code 1 (use -v to see invocation)
Is there any way to run it now or is it not supported?
AlekhyaV_Intel
Thank you for posting in Intel Communities. We could run a OpenCL sample with the below command in oneAPI command in node-s019-n011.
icpx -I/opt/intel/oneapi/compiler/latest/linux/include/sycl -lOpenCL openclsample.c
However, we are not able to run the binary executable and would end up with segmentation fault error. Please let us know you've observed the same.
If the above command doesn't work for you, we would like to look at your OpenCL sample code. Could you please share it?
Please accept this as a solution if this helps resolving your issue. This helps others with similar issue. Thank you!
Alekhya
AlekhyaV_Intel
Alekhya
AlekhyaV_Intel
Has the solution provided helped? Could you please give us an update regarding this issue?
Alekhya
dyedd
Thank you. This method is very effective. In addition, replacing dpcpp with the above command 'clang' also has the same effect。
AlekhyaV_Intel
Glad to know that your issue is resolved. Thank you for accepting our solution. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
