Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1467 Discussions
Can't SSH login to DevCloud wuth Warning message "WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!"
sche248
Hello DevCloud team,
I'd been apply to DevCloud last year and return with another enroll apply,
But this time with Cygwin auto configure, I can't use SSH to login the DevCloud with below message.
I tried the chmod 600 ~/.ssh/devcloud-access-key-xxxxx.txt chmod 600 ~/.ssh/config solution and it's not working.
I found there's two key in my ssh folder, not sure if it's related.
AthiraM_Intel
Thank you for posting in Intel communities.
Could you please remove the old key and then try to connect DevCloud.
Also run the following commands:
Make sure that the key name in the command is same as the key present in the folder.
If the issue still persists, please remove the known_hosts from the folder and try to connect again.
If you face any issue, please let us know.
AthiraM_Intel
Could you please give us an update? Is your issue resolved?
AthiraM_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
