- Tags:
- General Support
Hi Kalyan,
Thanks for reaching out to us!
On Devcloud, we are having dedicated compute nodes which are having FPGA hardware. As per the logs provided by you, we observed that the node which you are running your application contains only an FPGA Emulation device but does not contain FPGA hardware.
We suggest you acquire an FPGA hardware node via an interactive terminal or submit a job to a node that has FPGA hardware.
Example of Job submission for FPGA hardware node.
qsub -l nodes=1:fpga_runtime:ppn=2,walltime=08:00:00 -d . build_fpga_hw.sh (arg Small L(-l)).
Example of an interactive terminal
qsub -I -l nodes=1:fpga_runtime:ppn=2 (1st arg: Captial i (-I), 2nd arg: Small L(-l)).
If you want to compile and run your application on the FPGA Emulation device, use the below commands.
Example of Job submission for FPGA Emulation node.
qsub -l nodes=1:fpga_compile:ppn=2,walltime=08:00:00 -d . myscript.sh (arg Small L(-l)).
qsub -I -l nodes=1:fpga_compile:ppn=2 (1st arg: Captial i (-I), 2nd arg: Small L(-l)).
As FPGA issues are not handled here. If you have any issues related to FPGA, please ask your question in the Intel® High Level Design Forum.
Goutham
Thanks Goutham.
I am using below command which causing this problem. Let me change this command as you suggest.
qsub -l nodes=1:gpu:ppn=2 -d . $script
Kalyan-G.
Hi Kalyan,
Could you please let us know if your issue still persists.
If it is resolved, please do let us know if we can close this thread.
Thanks & Regards
Goutham
Hi Kalyan,
Could you please let us know whether we can close this thread if your issue is resolved?
If your issue still persists, please do let us know. So that we will be able to help you with that.
Goutham
Hi Goutham,
Apology for delayed reply. Your suggestion works good. now i could able to access the FPGA device by using 'qsub -l nodes=1:fpga_runtime:ppn=2' node. thanks for your support.
please close this ticket.
Kalyan-G
Hi Kalyan,
Glad to hear that solution provided helped you.!
We are closing this thread.
Please feel free to raise new threads in case of any further issues.
Have a Good day!
Goutham
