Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1693 Discussions
Can‘t build DPC++ with CMake
cp_cp
I want to build a project in DPC++ with CMake in the DevCloud.
This is the error I encountered.
And this is the CMakeLists.txt file.
I cannot figure out why this bug emerge.
AthiraM_Intel
Please try the below commands before building the cmake file.
source /opt/intel/oneapi/compiler/latest/env/vars.sh
export PATH=$PATH:/opt/intel/oneapi/compiler/latest/linux/bin-llvm/
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Thank you
cp_cp
Good evening.
Unluckily , It triggered another error.
Is there any libs I have not installed?
AthiraM_Intel
Please make sure that you source oneAPI environment variables before building the sample using the below command:
source /opt/intel/oneapi/setvars.sh --force
After this command you can export the below commands
If the issue still persists, please share the sample reproducer code and the exact steps you followed.
Also share the output of below 2 commands:
echo $PATH
echo $LD_LIBRARY_PATH
AthiraM_Intel
We have not heard back from you. Could you please give us an update? Is your issue resolved?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
