I followed the recipe to connect to devcloud through my pre-installed cygwin environment, but I can't get into devcloud. When I run the "ssh devcloud+proxy" I end up with the terminal blocked and when I hit return, ssh shows "protocol mismatch" and then I have to kill it through CTRL+C. Any idea on what might be wrong and/or how to fix this?
$ ssh -v devcloud+PROXY OpenSSH_8.1p1, OpenSSL 1.1.1d 10 Sep 2019 debug1: Reading configuration data /home/xyz/.ssh/config debug1: /home/xyz/.ssh/config line 257: Applying options for devcloud+PROXY debug1: Executing proxy command: exec nc -x proxy-ir.intel.com:1080 devcloud.intel.com 22 debug1: identity file /home/xyz/.ssh/devcloud-access-key-42705.txt type -1 debug1: identity file /home/xyz/.ssh/devcloud-access-key-42705.txt-cert type -1 debug1: Local version string SSH-2.0-OpenSSH_8.1 debug1: Remote protocol version 2.0, remote software version OpenSSH_7.4 debug1: match: OpenSSH_7.4 pat OpenSSH_7.0*,OpenSSH_7.1*,OpenSSH_7.2*,OpenSSH_7.3*,OpenSSH_7.4*,OpenSSH_7.5*,OpenSSH_7.6*,OpenSSH_7.7* compat 0x04000002 debug1: Authenticating to devcloud.intel.com:22 as 'guest' debug1: SSH2_MSG_KEXINIT sent debug1: SSH2_MSG_KEXINIT received debug1: kex: algorithm: curve25519-sha256 debug1: kex: host key algorithm: ecdsa-sha2-nistp256 debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none debug1: expecting SSH2_MSG_KEX_ECDH_REPLY debug1: Server host key: ecdsa-sha2-nistp256 SHA256:A43Fccb1iM4pDwsT5OgjszJYHAJdaMmA4fV2hf1HmVo debug1: Host 'devcloud.intel.com' is known and matches the ECDSA host key. debug1: Found key in /home/xyz/.ssh/known_hosts:70 debug1: rekey out after 134217728 blocks debug1: SSH2_MSG_NEWKEYS sent debug1: expecting SSH2_MSG_NEWKEYS debug1: SSH2_MSG_NEWKEYS received debug1: rekey in after 134217728 blocks debug1: Will attempt key: /home/xyz/.ssh/devcloud-access-key-42705.txt explicit debug1: SSH2_MSG_EXT_INFO received debug1: kex_input_ext_info: server-sig-algs=<rsa-sha2-256,rsa-sha2-512> debug1: SSH2_MSG_SERVICE_ACCEPT received debug1: Authentications that can continue: publickey,gssapi-keyex,gssapi-with-mic debug1: Next authentication method: publickey debug1: Trying private key: /home/xyz/.ssh/devcloud-access-key-42705.txt debug1: Authentication succeeded (publickey). Authenticated to devcloud.intel.com (via proxy). debug1: Local connections to LOCALHOST:4022 forwarded to remote address c009:22 debug1: Local forwarding listening on ::1 port 4022. debug1: channel 0: new [port listener] debug1: Local forwarding listening on 127.0.0.1 port 4022. debug1: channel 1: new [port listener] debug1: channel 2: new [client-session] debug1: Requesting no-more-sessions@openssh.com debug1: Entering interactive session. debug1: pledge: proc debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0 debug1: Remote: Forced command. SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3 Protocol mismatch. debug1: client_input_channel_req: channel 2 rtype exit-signal reply 0 debug1: client_input_channel_req: channel 2 rtype eow@openssh.com reply 0 ^Cdebug1: channel 2: free: client-session, nchannels 3 debug1: channel 0: free: port listener, nchannels 2 debug1: channel 1: free: port listener, nchannels 1 Connection to devcloud.intel.com closed. Transferred: sent 2712, received 2628 bytes, in 14.6 seconds Bytes per second: sent 185.7, received 180.0 debug1: Exit status -1
- Tags:
- General Support
We tried connecting Devcloud through the Cygwin environment and it's working fine for us. Could you please follow the below steps.If you have done already,skip that step.
Step 1: Download CYGWIN: 64 bit version from https://www.cygwin.com/ and run the setup with the --no-admin option.
For more information on installation, please go through: https://devcloud.intel.com/datacenter/learn/connect-with-ssh-windows-cygwin/installation Note: If you have installed it already, skip to the next step.
Step 2: Open the Cygwin Terminal and set up SSH tunneling as described below for connecting to Intel AI Devcloud.
- Download and save the SSH access key for Linux/macOS to the folder ~/Downloads/ on your computer and remove the ".txt" extension from the key name. Create the directory ~/.ssh, unless it already exists and copy the key file devcloud-access-key-XXXXX to ~/.ssh.
mkdir -p ~/.ssh mv ~/Downloads/devcloud-access-key-<user> ~/.ssh/
- Create a config file in ~/.ssh folder. For that add the following lines in ~/.ssh/config file.
Host devcloud_proxy User uXXXXX HostName c009 Port 4036 IdentityFile "<path to>/.ssh/devcloud-access-key-XXXXX" ProxyCommand ssh -T devcloud-socks-proxy Host devcloud-socks-proxy User guest Hostname cluster.colfaxresearch.com IdentityFile "<path to>/.ssh/devcloud-access-key-XXXXX" LocalForward 4036 colfaxserver:22 ProxyCommand nc -x proxy-us.intel.com %h %p
Connect to devcloud:
ssh devcloud_proxy
Hopes this helps. Please feel free to reach out to us if you have any issues.
Could you please confirm whether you are able to connect Devcloud through Cygwin with the solution provided.
Hi
We are closing this case by assuming that your issue got resolved. Please feel free to raise a new thread if you have any further issues
