Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1352 Discussions
Can't download anything on DevCloud
atuft
I'm logged in to DevCloud and would like to download some files using git clone and wget, but the login node complains that it can't resolve hosts:
wget https://www.google.com
--2022-06-15 02:57:30--  https://www.google.com/
Resolving www.google.com (www.google.com)... failed: Name or service not known.
wget: unable to resolve host address 'www.google.com'
git clone https://github.com/oneapi-src/oneAPI-samples.git
Cloning into 'oneAPI-samples'...
fatal: unable to access 'https://github.com/oneapi-src/oneAPI-samples.git/': Could not resolve host: github.com
atuft
It seems I can download when connected to a compute node, so this issue only seems to be on the login node
AthiraM_Intel
Good day to you.
For your information, login node uses a lightweight general-purpose processor. Login nodes should not be used for development or execution of programs. It is an interface node that helps to connect or submit jobs to compute nodes.
We request you to use compute nodes to download or clone repositories.
Since your issue is resolved, we are closing this case. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
プロファ
Can I use wget to download resources from my login node?
