Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Cannot SSH using Linux. Error Message is "Ncat: Connection timed out."
Cinly_O_Intel
I can get into Jupyter no problem, but not SSH from Fedora29. I am in Intel Malaysia and I need  proxy to access non-intel site from the F29 machine.
Here is what I get
<code>
$ cat ~/.ssh/config
## Note, I masked off User  and Port information with XXXXX and 9999
Host devcloud
        User uXXXXX
        Port 9999
        IdentityFile /home/cinlyooi/.ssh/devcloud-access-key-XXXXX.txt
        ProxyCommand ssh -T devcloud-via-proxy
Host devcloud-via-proxy
        User guest
        Hostname devcloud.intel.com
        IdentityFile ~/.ssh/devcloud-access-key-XXXXX.txt
        LocalForward 9999 c009:22
        ProxyCommand nc -x proxy-chain.intel.com:1080 %h %p
$ ssh devcloud
ssh_exchange_identification: Connection closed by remote host
</code>
For 'nc -x' options,
For devcloud-via-proxy,
  • I tried "Hostname cluster.colfaxresearch.com" from the same forum thread, and
  • I tried "LocalForward 9999 colfaxserver:22" from https://software.intel.com/en-us/forums/intel-devcloud/topic/831593
but have no luck.
Appreciate any help I can get.
Many thanks and happy new year
Cinly
ChithraJ_Intel
Could you please try with the following config file.
Host colfax_proxy
User uXXXXX
HostName c009
Port 4036
IdentityFile /home/mobaxterm/key/colfax-access-key-XXXXX
ProxyCommand ssh -T devcloud-socks-proxy
Host devcloud-socks-proxy
User guest
LocalForward 4036 colfaxserver:22
#ProxyCommand nc -x  proxy-us.intel.com %h %p
ProxyCommand nc -x proxy.jf.intel.com %h %p
Hope it helps. Please feel free to reach out to us for further issues.
Srilekha_P_Intel
Hi, Thank you for reaching us. Could you please confirm us whether you are able to connect from external network or not?
Cinly_O_Intel
Hi Srilekha
Thank you for your reply. Sorry for the late reply. This is because timezone issue (GMT+8 here) means anything you ask me to do outside Intel will mean at least a 24 hour delay because I have to leave work for home first and this time extra delay was caused by the weekend.
I can confirm I can connect from external network using the non-proxy-based approach.
Any idea on what can I try to resolve the issue?
Many thanks
cinly
ChithraJ_Intel
Host colfax_proxy
User uXXXXX
HostName c009
Port 4036
User guest
Cinly_O_Intel
Thank you Chithra, after switching the IdentifyFile to devcloud's, and changing the proxy to the socks proxy and port, I managed to login.
Thank you.
Cinly
ChithraJ_Intel
Glad to hear that it is worked for you.
We are closing the case. Please feel free to raise a new thread in case you face any further issues.
