I can get into Jupyter no problem, but not SSH from Fedora29. I am in Intel Malaysia and I need proxy to access non-intel site from the F29 machine.
Here is what I get
<code>
$ cat ~/.ssh/config ## Note, I masked off User and Port information with XXXXX and 9999 Host devcloud User uXXXXX Port 9999 IdentityFile /home/cinlyooi/.ssh/devcloud-access-key-XXXXX.txt ProxyCommand ssh -T devcloud-via-proxy Host devcloud-via-proxy User guest Hostname devcloud.intel.com IdentityFile ~/.ssh/devcloud-access-key-XXXXX.txt LocalForward 9999 c009:22 ProxyCommand nc -x proxy-chain.intel.com:1080 %h %p $ ssh devcloud Ncat: Connection timed out. ssh_exchange_identification: Connection closed by remote host ssh_exchange_identification: Connection closed by remote host
</code>
For 'nc -x' options,
- I tried child-prc.intel.com, proxy-us.intel.com, proxy-png.intel.com following examples from https://software.intel.com/en-us/forums/intel-devcloud/topic/837106. ;
For devcloud-via-proxy,
- I tried "Hostname cluster.colfaxresearch.com" from the same forum thread, and
- I tried "LocalForward 9999 colfaxserver:22" from https://software.intel.com/en-us/forums/intel-devcloud/topic/831593
but have no luck.
Appreciate any help I can get.
Many thanks and happy new year
Cinly
- Tags:
- General Support
Could you please try with the following config file.
Host colfax_proxy User uXXXXX HostName c009 Port 4036 IdentityFile /home/mobaxterm/key/colfax-access-key-XXXXX ProxyCommand ssh -T devcloud-socks-proxy Host devcloud-socks-proxy User guest Hostname cluster.colfaxresearch.com IdentityFile /home/mobaxterm/key/colfax-access-key-XXXXX LocalForward 4036 colfaxserver:22 #ProxyCommand nc -x proxy-us.intel.com %h %p ProxyCommand nc -x proxy.jf.intel.com %h %p
Hope it helps. Please feel free to reach out to us for further issues.
Hi Srilekha
Thank you for your reply. Sorry for the late reply. This is because timezone issue (GMT+8 here) means anything you ask me to do outside Intel will mean at least a 24 hour delay because I have to leave work for home first and this time extra delay was caused by the weekend.
I can confirm I can connect from external network using the non-proxy-based approach.
Any idea on what can I try to resolve the issue?
Many thanks
cinly
Thank you Chithra, after switching the IdentifyFile to devcloud's, and changing the proxy to the socks proxy and port, I managed to login.
Thank you.
Cinly
Glad to hear that it is worked for you.
We are closing the case. Please feel free to raise a new thread in case you face any further issues.
