I was trying to login into one of the Arria 10 PAC nodes but was unable to enter.
u155995@login-2:~$ devcloud_login
You are selecting an interactive compute server sesssion. Please consider using batch mode submission using
devcloud_login -b to not tie up compute servers with idle sessions.
See the help menu using devcloud_login -h for more details.
What are you trying to use the Devcloud for?
1) Arria 10 PAC Compilation and Programming - RTL AFU, OpenCL
2) Arria 10 - OneAPI, OpenVINO
3) Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL
4) Stratix 10 - OneAPI, OpenVINO
5) Compilation (Command Line) Only
6) Enter Specific Node Number
Number: 1
Which Arria 10 PAC Development Stack release would you like to source?
0) 1.2
1) 1.2.1
Number: 1
For X2GO tunneling access. For users connected to intel firewall, copy and paste the following text in a new mobaxterm terminal:
ssh -L 4002:s005-n007:22 colfax-intel
For X2GO tunneling access. For users NOT connected to intel firewall, copy and paste the following text in a new mobaxterm terminal:
ssh -L 4002:s005-n007:22 devcloud
running: qsub -q batch@v-qsvr-fpga -I -l nodes=s005-n007:ppn=2
qsub: submit error (Unauthorized Request MSG=group ACL is not satisfied: user u155995@login-2.aidevcloud, queue batch)
u155995@login-2:~$
u155995@login-2:~$ groups
u155995
It seems that I don't have access to it. Is it possible to give me access to it?
Yes I followed the whole setup until 5.3 where I starting looking at the quickstart guides.
Hi Dcupello,
May I know can you access to other board selection other than the one you mentioned?
Aik Eu
I cannot access "Stratix 10 PAC Compilation and Programming - RTL AFU, OPENCL". I can access the rest.
Hi Dcupello,
Sorry for late reply.
On my side I have no issue to make the selection (Number1 then Number1) that you were not able to.
Anyway can try with other nodes by select Number 6(Enter Specific Node Number) and from that list below, select one of the nodes:
Release 1.2:
Release 1.2.1:
s001-n137 s001-n138 s001-n139 s005-n001 s005-n002 s005-n003 s005-n004
Try select s005-n004 or other ones and see if it works.
I will try to notify the devcloud team on this findings.
Aik Eu
No worries. I tried entering s005-n004 and it does not work. I have been reading on this and it seems like the reason I can't is because I am not in the c009 group. I have been trying to see if I can get access to that group but have not been successful. Is it possible for anyone to give my account access to this group?
Many Thanks
Hi Dcupello,
Since this is related to account issue, I will route this issue to account team to advise on the group access.
Aik Eu
Hi Dcupello,
Can try to access the board again?
I was informed that permission has been given for the access of c009 group.
I will close this thread and follow up with you in email if there is still issue with the access.
Aik Eu
Hi aikeu,
I am now able to access it with no problems. Thank you very much for your support!
Dcupello
