Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1352 Discussions
Cannot connect to devcloud through SSH since June 24th
z24tao
Error:
no such identity: /Users/derek/.ssh/id_pub: No such file or directory
guest@ssh.devcloud.intel.com: Permission denied (publickey).
kex_exchange_identification: Connection closed by remote host
Connection closed by UNKNOWN port 65535
I tried getting a new key, however it appears I get a 500 internal server error on this link:
https://devcloud.intel.com/oneapi/download_ssh/?asset=ssh_key
Please help!
AlekhyaV_Intel
Thank you for posting in Intel Communities. We sincerely apologize for the inconvenience caused. DevCloud was down from past two days. You can try the below steps to re-connect to devcloud again.
1) Download the new key from this link: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
2) Move/Copy this file to ~/.ssh folder & rename it to "devcloud-access-key-xxxxx.txt"
3) Give permissions to the file/folder as below:
chmod 600 ~/.ssh/devcloud-access-key-xxxxx.txt
chmod 600 ~/.ssh/config
(Ignore this step if you're connecting through Mobaxterm. This step is required only for Cygwin.
If this resolves your issue, please accept this as a solution as it might help others with the similar issue. Thanks in advance. Please let us know if this issue still persists.
Alekhya
AlekhyaV_Intel
Alekhya
z24tao
Thanks! I am now able to access devcloud.
ral
@AlekhyaV_Intel The link suggested does not work, I get a "Service Unavailable" error when trying to load it
AlekhyaV_Intel
Hi @ral ,
Sincere apologies for the inconvenience caused. Try clearing the cache or opening that page in incognito. And we sent a private mail to get your DevCloud ID. We would be handling your issue here (https://community.intel.com/t5/Intel-DevCloud/host-key-change/td-p/1394584/page/2).
Alekhya
AlekhyaV_Intel
Hi @z24tao ,
Thank you for accepting our solution. If you need any further assistance, please post a new question as this thread would no longer be monitored by Intel.
Alekhya
