Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
Cannot kill job in queue
chiara_vaudano
Hello Admin
I am not able to kill a process in job queue.
It has been in run mode for days. When I try to use qdel, I receive the following error:
qdel: Server could not connect to MOM 805341.v-qsvr-1.aidevcloud
My user is:
u****
Thanks and regards,
Chiara
ArunJ_Intel
Hi
We have informed the admin team regarding this. We will soon get back to you with an update.
Arun
ArunJ_Intel
Hi
Could you please check whether your job is still running because ideally it should be killed within 24 hours. If it is still running please send us output of the below command.
qstat -n
Arun
chiara_vaudano
Hi Admin,
the job is still in run mode.
The output of 'qstat -n' command is:
v-qsvr-1.aidevcloud:
        Req'd       Req'd       Elap
Job ID                  Username    Queue    Jobname          SessID  NDS   TSK   Memory      Time    S   Time
805341.v-qsvr-1.aidevc  u61892      batch    STDIN             21535     4      8       --   24:00:00 R 189:33:44
   s001-n003/0-1+s001-n021/0-1+s001-n022/0-1+s001-n023/0-1
810146.v-qsvr-1.aidevc  u61892      batch    STDIN             27780     1      2       --   24:00:00 R  13:41:44
   s001-n020/0-1
810329.v-qsvr-1.aidevc  u61892      jupyterh jupyterhub-singl  16084     1      1      94gb  04:02:00 R  00:34:06
   s001-n002/0
The job id of the blocked process is 805341.
Thanks and regards,
Chiara
ArunJ_Intel
Hi
Arun
chiara_vaudano
Thanks for the support.
The job has been killed.
Chiara
ArunJ_Intel
Hi
Thanks for the confirmation. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Arun Jose
