Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1713 Discussions
Cannot log into devcloud by .ssh
Renan1
When using the ssh terminal, I get the following error:
AthiraM_Intel
Could you please let us know which DevCloud you are using? Is it DevCloud for Edge/oneAPI?
If you are using DevCloud for oneAPI, please check whether you are able to use jupyterlab?
Renan1
Yes, through Jupyter it works fine.
AthiraM_Intel
We assume that the issue is not with you account as you are able to connect oneAPI DevCloud via JupyterLab. It could be either with the config file or could be due to proxy settings.
Hence, we recommend you to delete the setup and files created and redo it as mentioned below.
1. Sign in here and follow the steps given in automatic configuration(option 1). When the script is executed in your terminal you can find a configuration file created ~/.ssh/config.
2. If you are connected to proxy, edit the config file with the proxy_name, hostname and port number
After the above steps, you should be able to log in to Intel DevCloud using the command
ssh devcloud
or if connected to proxy
ssh devcloud.proxy
If the issue still persist, please share the config file with us in private.
Renan1
I keep getting the following error
I used the proxy commands to set the proxy:
And changed this to the server and port 912
AthiraM_Intel
We could see that the you have given host name as "devcloudx" from your screenshot.
Could you please try the below command to access DevCloud.
ssh devcloudx
If you face any further issue, please let us know.
Thank you!
Renan1
Tried all of those commands, and it still cannot be found.
AthiraM_Intel
We could see that the .ssh folder is in "C:\Users". .ssh folder should be in "C:\Users\<user-name>"
Then try to connect DevCloud using below command:
ssh devcloudx
Make sure that you followed the below documentation to set up connection to DevCLoud for oneAPI on Windows:
https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-openssh/
AthiraM_Intel
We have not heard back from you. Could you please give us an update? Is your issue resolved?
AthiraM_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
