Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1642 Discussions
Changing environment in Jupyter Lab in devcloud
Saransh
I wanted to run a jupyter lab notebook with a separate environment / kernel than the one available in the selection. A custom environment that I myself created using CLI.
How do I use that conda environment in the jupyter notebooks in JupyterLab?
Saransh
AthiraM_Intel
You could follow the below steps to add new environment in the jupyter notebook.
1. Activate the new environment
   source activate <env_name>
2. Install ipykernel
   conda install ipykernel
3. Add new kernel in jupyter notebook
   python -m ipykernel install --user --name <env_name>
4. Open the jupyter lab and set the kernel to this environment
   Kernel-->change kernel --> select one you want
If you face any issue, please let us know.
Saransh
AthiraM_Intel
Thanks for the confirmation. If you need any additional information, please submit a new question as this thread will no longer be monitored.
