I wanted to run a jupyter lab notebook with a separate environment / kernel than the one available in the selection. A custom environment that I myself created using CLI.
How do I use that conda environment in the jupyter notebooks in JupyterLab?
Saransh
You could follow the below steps to add new environment in the jupyter notebook.
1. Activate the new environment
source activate <env_name>
2. Install ipykernel
conda install ipykernel
3. Add new kernel in jupyter notebook
python -m ipykernel install --user --name <env_name>
4. Open the jupyter lab and set the kernel to this environment
Kernel-->change kernel --> select one you want
If you face any issue, please let us know.
Thanks for the confirmation. If you need any additional information, please submit a new question as this thread will no longer be monitored.
