Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1464 Discussions
Connection closed by remote host
rod_figs
I've got this message for the last 7 days:
guest@ssh.devcloud.intel.com: Permission denied (publickey).
kex_exchange_identification: Connection closed by remote host
I already modified the known_hosts file. What's wrong?
Rahila_T_Intel
Please be informed that each user is allowed only one account on the oneAPI DevCloud and you can continue to use your original account for your academic/learning purposes.
Please use your original account(that account is active), which we will inform you through private message.
Rahila_T_Intel
Sincere apologies for the inconvenience caused. As DevCloud has migrated to new SSH server, some of devcloud users are facing this issue.
Could you please try the below steps to re-connect to devcloud again.
 1) Download the new key from this link: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
2) Move/Copy this file to ~/.ssh folder & rename it to "devcloud-access-key-xxxxx.txt"
3) Give permissions to the file/folder as below:
chmod 600 ~/.ssh/devcloud-access-key-xxxxx.txt
chmod 600 ~/.ssh/config
(Ignore this step if you're connecting through Mobaxterm. This step is required only for Cygwin.
You can try to access Jupyter notebook through the below link. Please scroll to the bottom and launch jupyter notebook.
https://devcloud.intel.com/oneapi/get_started/
If you are still facing this issue please let us know whether your DevCloud account is active or not (Check DevCloud expiry date).
rod_figs
I followed the steps but I got the same message.
When I tried to launch jupyter notebook I got 500 : Internal Server Error.
Expiration Date : 10/19/2022
nka
Same over here.
Rahila_T_Intel
We understand your concern. Sincere apologies for the inconvenience caused.
As DevCloud has migrated to new SSH server, some of devcloud users are still facing this issue.
We are currently looking into it.
We will connect with you through private email/message to get your DevCloud user ID.
rod_figs
The account was running ok a few hours ago. I uploaded the files and put some jobs to run. Suddenly, the files were deleted and soon after I lost access to the account.
So many problems... frustrating....
Rahila_T_Intel
We are working on this internally and will share you the updates.
Rahila_T_Intel
Rahila_T_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
