Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1689 Discussions
Connection to devcloud/oneAPI via ssh: login message: "Process exceeded login node resource limit."
FHuelsemann
Dear Devclouders, trying (and succeeding) to connect to devcloud/oneAPI via ssh results in the following message/warning (in red) before displaying the bash prompt:
Please run jobs on compute nodes using qsub or start an interactive shell using qsub -I.
Please visit the forums at: https://software.intel.com/en-us/forums/intel-devcloud
Well, what can I do to use the resources responsibly?
Best regards, Frank
ThasneemV_Intel
Please note that the message you received is merely a warning that is displayed intermittently. It can be ignored as it does not impose any limitations on functionality.
To access the compute node, you can use the following command:
qsub -I
If this resolves your issue, kindly make sure to accept this as a solution. This would help others with similar issues.
Thasneem Vazim
ThasneemV_Intel
qsub -I
Thasneem Vazim
