Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1467 Discussions
Connectivity to github.com
rmterpst
Following steps @ https://devcloud.intel.com/oneapi/get_started/aiAnalyticsToolkitSamples/
I have succesfully connected via SSH, but when attempting "2 Run a Hello World Sample" step to clone the github repo I can't connect:
uXXXXXX@login-2:~$ git clone https://github.com/oneapi-src/oneAPI-samples.git
Cloning into 'oneAPI-samples'...
fatal: unable to access 'https://github.com/oneapi-src/oneAPI-samples.git/': Could not resolve host: github.com
Are there undocumented steps to enable connectivity to github?
RemyaP_Intel
For your information, login node uses a lightweight general-purpose processor. Login nodes should not be used for development or execution of programs. It is an interface node that helps to connect or submit jobs to compute nodes.
DevCloud does not allow external website access from the login node. External access is allowed only from compute nodes.
As you already know, we can use compute nodes to download or clone repositories. However, the downloaded files would be available in the cloud, so you can access them in login node and compute node as well.
Remya Premdas
RemyaP_Intel
We have not received any response from you. Has your issue been resolved?
Remya Premdas
RemyaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
