Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1348 Discussions
Corrupted access key, need to reissue new access key
ICHIKAWA__kento
I have corrupted .ssh directory, and I can not login to devcloud server via ssh login. I would like to have new accesskey reissued from Inted DevCloud administration. How can I request a reissue?
ChithraJ_Intel
Hi Kento,
Since your key is not corrupted, you can make use of same key itself to login to devcloud server. For that,
  • Delete the existing .ssh directory and try to download the key again from devlcoud welcome mail documentation.
           rm -r ~/.ssh
  • Create a new ~/.ssh directory, and move the private SSH key into permanent storage in ~/.ssh as follows:
           mkdir -p ~/.ssh
           mv <path to downloaded key>/devcloud-access-key-xxxxx.txt ~/.ssh/
  • Create the config file again in ~/.ssh folder as mentioned in documentation.
  • Manually verify whether the key file is present in the ~/.ssh folder and set correct permissions as below:
           chmod 600 ~/.ssh/devcloud-access-key-xxxxx.txt
           chmod 600 ~/.ssh/config
[Note : Please make sure that the correct path and name of the key is provided in the config file.]
Hope it helps. Please feel free to reach out to us if you further face any issues.
ChithraJ_Intel
Hi Kento,
Could you please confirm whether the solution provided is helped for you.
ICHIKAWA__kento
I tried the provided solution. But it does not works. I am required password authentification.
OpenSSH_8.1p1, OpenSSL 1.1.1d  10 Sep 2019
debug1: Reading configuration data /Users/kent/.ssh/config
debug1: /Users/kent/.ssh/config line 1: Applying options for devcloud
debug1: Reading configuration data /usr/local/etc/ssh/ssh_config
debug1: Executing proxy command: exec ssh -T -i ~/.ssh/devcloud-access-key-34082.txt guest@devcloud.intel.com
debug1: identity file /Users/kent/.ssh/devcloud-access-key-34082.txt type -1
debug1: identity file /Users/kent/.ssh/devcloud-access-key-34082.txt-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.1
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
debug1: match: OpenSSH_7.6p1 Ubuntu-4ubuntu0.3 pat OpenSSH_7.0*,OpenSSH_7.1*,OpenSSH_7.2*,OpenSSH_7.3*,OpenSSH_7.4*,OpenSSH_7.5*,OpenSSH_7.6*,OpenSSH_7.7* compat 0x04000002
debug2: fd 5 setting O_NONBLOCK
debug2: fd 4 setting O_NONBLOCK
debug1: Authenticating to devcloud:22 as 'u34082'
debug3: hostkeys_foreach: reading file "/Users/kent/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /Users/kent/.ssh/known_hosts:2
debug3: load_hostkeys: loaded 1 keys from devcloud
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: host key algorithms: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:7R/nUuhf2mWQej8YRr+FNr0T0++Rw71wmvZpsrysbFU
debug1: Host 'devcloud' is known and matches the ECDSA host key.
debug1: Found key in /Users/kent/.ssh/known_hosts:2
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug1: rekey in after 134217728 blocks
debug1: Will attempt key: /Users/kent/.ssh/devcloud-access-key-34082.txt  explicit
debug2: pubkey_prepare: done
debug3: send packet: type 5
debug3: receive packet: type 7
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /Users/kent/.ssh/devcloud-access-key-34082.txt
debug3: sign_and_send_pubkey: RSA SHA256:FdjaR7ZSHXwLb0zBe7LenjPPCYkOUlDV551YauPhdiw
debug3: sign_and_send_pubkey: signing using rsa-sha2-512
debug2: we sent a publickey packet, wait for reply
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
u34082@devcloud's password:
ICHIKAWA__kento
I guess I have deleted my public key on devcloud server side
ICHIKAWA__kento
Self resolved the problem. I have copied self-generated public key to .ssh/authorized_key2 using Jupyter. The key worked!
Thank you for your help!
ChithraJ_Intel
Hi Kento,
Since your issue is resolved, we are closing this case.
Please feel free to raise a new thread if you have further issues.
