- Email to a Friend
I need to install the following depencencies:
libbz2-dev
liblzma-dev
An apt-install without sudo fails to install the package. I tried to look for the source code so that I can use autotools but I was only able to locate a .deb file, and upon extraction, there was no "bin" folder
How should I go about this?
- Email to a Friend
Sorry for the inconvenience, User's don't have admin privileges in DevCloud.
Intel DevCloud® is a shared environment which comes with pre-installed validated Intel® oneAPI software and complimentary packages. As a policy we do not install custom (open source or 3rd party licensed) software to the environment and recommend that you explore available and equivalent oneAPI SW tools or components. You may be able to install software locally in your user folder using < > “pip install –user” (dash dash user switch allows you to install local in your home directory)
- Email to a Friend
- Email to a Friend
Thanks for accepting our solution. If you need any additional information, please submit a new question as this thread will no longer be monitored.
