Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
DevCloud GPUs
TestDR1
I am using intel devcloud for GPU offloading test.  I used the following command to see available nodes
pbsnodes | grep "properties =" | awk '{print $3}' | sort | uniq -c
   22 core,tgl,i9-11900kb,ram32gb,netgbe,gpu,gen11
     78 xeon,cfl,e-2176g,ram64gb,net1gbe,gpu,gen9
      4 xeon,clx,ram192gb,net1gbe,batch,extended,fpga,stratix10,fpga_runtime
      6 xeon,icx,gold6348,ramgb,netgbe,jupyter,batch
      4 xeon,icx,plat8380,ram2tb,net1gbe,batch
      3 xeon,skl,gold6128,ram192gb,net1gbe,fpga_runtime,fpga,agilex
     12 xeon,skl,gold6128,ram192gb,net1gbe,fpga_runtime,fpga,arria10
     79 xeon,skl,gold6128,ram192gb,net1gbe,jupyter,batch
     26 xeon,skl,gold6128,ram192gb,net1gbe,jupyter,batch,fpga_compile
     12 xeon,skl,ram384gb,net1gbe,renderkit
      2 xeon,spr,ram1024gb,netgbe,dnp50
Based on above, there are 22 gpu,gen11 and 78 gpu,gen9.  It looks to me these GPUs are Intel(R) UHD Graphics. Is that correct? Is there any way to run my code on latest intel discrete GPU such as Iris Xe Max and if so how to I specify that with "-l nodes" ?  For example, for generic gpu, I use qsub -l nodes=1:gpu:ppn=2.
RajashekarK_Intel
Yes you are right and Unfortunately Intel DevCloud currently has only Integrated GPUs, for getting a compute node with GPU you can refer to the guide https://devcloud.intel.com/oneapi/documentation/job-submission/#:~:text=How%20to%20submit,an%20interactive%20session.
Rajashekar
RajashekarK_Intel
Hi, Good day to you.
We have not heard back from you. Is your issue resolved with the above information? If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Rajashekar
RajashekarK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel
Rajashekar
