Starting on April 29 (US Time), Intel DevCloud (oneAPI, Edge, and FPGA) will migrate to using Intel's universal authentication system. You will now be able to use your common Intel username and password to access the Intel® DevCloud as well as file downloads, support forums, and online training across intel.com.
Here is what you need to know:
- If you already have a login identity with Intel that is based on the same email address as your DevCloud account, you will be able to log in going forward without your DevCloud Key (UUID). (Following 4/29)
- If you do not have an existing login identity with Intel, you will receive an email by 4/29 from idm_reply@intel.com with the subject “Activate your new Intel account”. Follow the instructions to set your password for the first time.
This change is only related to logging on to the Intel DevCloud Website (http://devcloud.intel.com/oneapi). Connecting to the DevCloud via SSH remains the same, utilizing your SSH Key/configuration as usual.
Typical Username and Password issues may be experienced. If needed, you can perform a username recovery or a password reset
If you have any issues logging on to the website or connecting to the DevCloud, please submit an issue so we can help you resolve it.
