Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
DevCloud extension
couto__carlos
I am a researcher/professor at the University of Aveiro working with Intel DevCloud on AI related projects. A previous extension has been awarded to this account before and I am again renewing the request.
Can I get extension for my account is u58360? The actual expiration date is 08/30/2021.
JaideepK_Intel
Thank you for posting in Intel forums.
You can extend your Devcloud account in the link provided: https://www.intel.com/content/www/us/en/secure/forms/devcloud-extension/oneapi-request.html You have to add your project to Intel DevMesh and follow the required process given in the URL. Meanwhile, please back-up all your data to avoid any data loss. Let us know if you have any issues.
Jaideep
JaideepK_Intel
Your Account access is extended please check from your side and let us know.
Jaideep
couto__carlos
Thanks for the extension which I can see that is enabled.
However, when I try to login with Jupyter Hub the following error occurs:
500 : Internal Server Error
Error in Authenticator.pre_spawn_start: RuntimeError socket_connect_unix failed: 15137 socket_connect_unix failed: 15137 socket_connect_unix failed: 15137 qstat: cannot connect to server (null) (errno=15137) could not connect to trqauthd qstat: Error (15137 - could not connect to trqauthd)
I try to refresh and restart from the homepage but the error remains the same.
Best regards
JaideepK_Intel
Thank you for posting in Intel Communities. The jupyter issue is temporary. We are checking this with the internal team. We will get back to you as soon as we get an update.
Jaideep
JaideepK_Intel
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Thank you,
Jaideep
couto__carlos
Thanks for your reply. I can confirm that this is resolved. You may close this thread.
Carlos
JaideepK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
