Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1351 Discussions
DevCloud visualize fails with error
PRanganathan
Hi Experts
I am trying to perform object classification using Yolov4-darket, following are the steps performed
1. Anotated the image using OpenCVAT
2. Converted the image anotation to Pascal format
3. Downloaded the Yolov4-darknet model and the weights
4. Loaded the image in google colab [modified obj.names, obj,data,obj.cfg files], model and performed training and new weights were generated
5. tested the image using training set and it worked
6. converted the darknet to tensorflow2 format using the openvino guidelines  for the Downloaded new weights, config, .names, .data files
7.invoked the model optimizer to generate the IR files [.xml, .bin]
8. performed benchmarking usng benchmark app and got a good accuracy at 40fps
9. wanted to perform inference in Devcloud and got report on inference
10. when i wanted to visualize output in devcloud it failed with  "operands could not be broadcast together with shapes (8112,) (648960,) (8112,)"
can you pl. advise how to resolve the issue in step 10?
11. POst that i need to create a deployable for target Intel HW
warm rgds
PRanganatha
JesusE_Intel
Hi Pranganatha,
There may be an issue on how the model was converted from DarkNet to Tensorflow to IR. I was able to convert your model using the steps below and visualize output without any issues on DL Workbench. Could you give that a try and let me know the outcome?
git clone https://github.com/david8862/keras-YOLOv3-model-set
mkdir saved_model
python keras-YOLOv3-model-set\tools\model_converter\convert.py yolov4.cfg yolov4.weights saved_model
mo --saved_model_dir saved_model --input_shape [1,608,608,3] --model_name yolov4
These instructions were taken from here. Also, when importing the IR model to DL Workbench configure the models Inputs as NHWC for the Original Layout option.
Jesus
AthiraM_Intel
Could you please let us know which DevCloud you are using?(DevCloud for oneAPI/ Edge/ FPGA)
PRanganathan
Hi
Following are the links in sequence:
1. Dev Cloud: https://www.intel.com/content/www/us/en/developer/tools/devcloud/overview.html
2. Work With Intel OpenVINO : https://www.intel.com/content/www/us/en/developer/tools/devcloud/edge/overview.html
3. Build and Optimize -> Deep learning Workbench [https://notebooks.edge.devcloud.intel.com/user/u158442/lab/workspaces/auto-Z/tree/Reference-samples/iot-devcloud/dl-workbench/DLWorkbenchLauncher.ipynb?reset ]
4. Launch DL workbench , i was trying to test in NuC11 = i7 CPU[currently DLworkbench is down]
Thank you
rgds
JesusE_Intel
Hi PRanganatha,
Could you share your model in Tensorflow 2 format and model optimizer command used to convert to IR? If the model cannot be shared, could you share a link to the base model used for training? Could you also attach a screenshot of the error message? I just tested DL Workbench with YoloV4-TF model from the open model zoo and didn't run into any issues so this may be specific to your model.
Jesus
PRanganathan
Hi
Attaching the original model, saved model, weights, config file, IR converted set
JesusE_Intel
Hi Pranganatha,
mkdir saved_model
Jesus
JesusE_Intel
