Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Devcloud Access
VR2016
I'm  having trouble getting access(login issue) to DevCloud. I have tried both Cygwin and Linux , both gives me the same Error message:
Need some help with this.
ssh: Could not resolve hostname devcloud: Name or service not known.
-VR
AlekhyaV_Intel
Is the issue resolved? Please give us an update regarding this issue.
Alekhya
AlekhyaV_Intel
Thank you for posting in Intel Communities. Are you able to access Jupyter Notebook? Please make sure that you followed all the steps given in this documentation: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/
If this resolves your issue, make sure to accept this as a solution. This might help others with similar issue.
Alekhya
VR2016
Thanks for getting back. I'm able to access Jupyter Notebook, but ssh using Cygwin doesn't work. Have followed all the steps in the link above. I have logged in using Putty previously, isn't that available anymore?
Best,
-VR
AlekhyaV_Intel
  1. Please try downloading the key once again here: https://devcloud.intel.com/oneapi/download_ssh/?asset=ssh_config_script
  2. Follow the Manual configuration here: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/
  3. Make sure you've given the right restrictive permissions to the key & the config file. Set the correct restrictive permissions on the key and on the SSH client config file. To do this, run the following commands in a terminal:
chmod 600 ~/.ssh/devcloud-access-key-80713.txt
chmod 600 ~/.ssh/config
Alekhya
AlekhyaV_Intel
Alekhya
VR2016
I'm using Jupyter Notebook to access DevCloud. Have to give another try to Cygwin access.
-VR
AlekhyaV_Intel
Thank you for accepting our solution. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
