Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1720 Discussions
Devcloud oneapi login internal server error
priyansh1
I also get same error as like other I login with my devcloud account on oneapi and I get internal server error
My email: pjain2@cougars.ccis.edu
Please
JaideepK_Intel
Thank you for posting in intel communities.
Could you please follow the below steps?
  • Try to clear cache and cookies, and try to open from an incognito window.
  • We can see you are trying to access the devcloud from a mobile device. Could you please confirm that you are facing the same issue from your PC as well?
  • Please share more information about what you are trying to do so we can understand better.
Jaideep
priyansh1
Yes sir I tried all all things to try clear cookies try to login in incognito I tried all that other people tried I also login in pc but result was same internal server error please help me sir pleasee
JaideepK_Intel
We have contacted you privately via mail, please respond to that, also Could you please check if Jupyter is blocked: https://jupyter.oneapi.devcloud.intel.com/hub/login?next=/lab/tree/Welcome.ipynb?reset and getting the same server error.
Jaideep
priyansh1
yes same error in oneapi and edge and also in jupyter
JaideepK_Intel
We have sent you an email, please respond to that as soon as possible.
Jaideep
JaideepK_Intel
We have sent you an email, Could you please respond to that?
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
