Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1638 Discussions
Disable CPU frequency on DevCloud Xeon Nodes
r2
Hi all,
I am wondering whether it is possible to set the CPU frequency to it base frequency while benchmarking on the Xeon Nodes of the Intel DevCloud?
Is there a flag I can pass to qsub to achieve this, like `--cpufreq` as used with micctrl for XeonPhi?
Because on the node itself I won't have enough permissions to change the configuration.
Unfortunately, I couldn't find an exhaustive documentation of qsub.
Thank you very much.
Best regatds,
RR
Labels (2)
AthiraM_Intel
Could you please let us know which DevCloud (DevCloud for oneAPI/DevCloud for Edge) you are using?
r2
I am using DevCloud oneAPI. I specifically want to run some benchmarks on the ICX Xeon nodes, because I am interested in testing some optimisations regarding AVX512 VBMI and compare this to AVX2 and SSE4.
Please let me know if you need more information.
Many thanks and best regards,
RR
AthiraM_Intel
Thanks for the details. For your information, current Terms and Conditions of using DevCloud do not allow benchmarking or publishing any related results.
For more information on the Terms & Conditions of DevCloud usage refer https://www.intel.com/content/www/us/en/legal/terms-of-use.html , Section 9.2 prohibits publishing performance benchmarks.
If you have any further issue, please let us know.
r2
Thank you very much for referring to this.
Regarding the benchmarking, I'd like to point out, that I am doing these evaluation as member of the IPCC (Intel Parallel Computing Centre) FU Berlin, and I was explicitly forwarded to use the DevCloud for these experiments.
Is there maybe another way to get access to ICX as IPCC member?
And in any way, does there exist the possibility to disable frequency scaling from the user perspective in general (just a yes/no answer )?
Thank you very much for your support.
RR
AthiraM_Intel
We are checking on this internally, will get back to you with an update.
AthiraM_Intel
Since DevCloud is a worldwide resource, we will not be able to disable features requested as it may affect other users.
Best solution is to ask for a baremetal ICX to do experiments here :
https://Cloud.intel.com
Hope this helps. If you have any further issue, please let us know.
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
r2
Hi, I am sorry for not responding sooner.
I was in the middle of some deadlines and must have overseen your response.
I will ask for access for a baremetal ICX, as you suggested.
Many thanks for pointing this out to me and for your great assistance.
RR
