I am currently trying to use the DevCloud platform to train a RL model, which requires some external dependencies to be installed beforehand. To do so, I have created a Dockerfile, which generates an instance that has the dependencies installed, and uploaded it to a git repository. I have added the docker image onto Docker Hub as well.
However, I can't seem to be able to use the 'docker' command when logged in via ssh, so that I can compose or pull the image. Are there any steps I am missing ?
For context, the dependencies that the model I am trying to train require are the ones from the Robocup Soccer 3D Simulation League.
Thank you.
Thank you for posting in Intel Communities. Intel DevCloud is a shared environment which comes with pre-installed validated Intel oneAPI software and complimentary packages. As a policy we do not install custom (open source or 3rd party licensed) software to the environment. Docker is not supported in Intel DevCloud.
Alekhya
Alekhya
Thank you for accepting our solution. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
