As recently I got to know that Dev Cloud doesn't support Multinode for Artic Sound GPU, so wanted to understand does it support Multinode on any other GPUs.
Could you please let us know which DevCloud you are using? (DevCloud for oneAPI/Edge/FPGA)
You can access multiple gpu nodes in DevCloud using the below command:
qsub -I -l nodes=2:gpu:ppn=2 -d .
If you want to list the nodes allocated to you, please use below command:
echo $PBS_NODEFILE
After this you will get a path. You can open that file with cat command.
Please find the below screenshot for reference.
If you have any further issue, kindly let us know.
Could you please give us an update? Is your issue resolved?
For multi-node training with Intel XGBoost in DevCloud follow the steps mentioned in the below article.
https://medium.com/intel-analytics-software/distributed-xgboost-with-modin-on-ray-fc17edef7720
In DevCloud, multi-node computation is available through the job queue.
Syntax for multi-node:
qsub -l nodes=<count>:ppn=2
You can combine a request for multiple nodes with a request for their specific features.
Hope this helps.
We have not heard back from you. Could you please give us an update?
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
