Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1596 Discussions
Eigen3 installation on Intel Dev Cloud
Nitish_
Greetings,
I am accessing IntelDev Cloud for oneAPI through ssh. Since we don't have access to use sudo command, we are unable to install eigen library through :
sudo apt install libeigen3-dev
Neither could we build it from the source, as the command  "make install"  specified in below reference[1] requires admin privilege.
[1]. https://gitlab.com/libeigen/eigen/-/blob/master/INSTALL .
Are there alternative ways to use eigen library on IntelDev Cloud?
Thank you.
Warm regards,
Nitish
Nitish_
I was able to successfully use the eigen library without installation as depicted in method 1 of reference [1].
We can use right away the headers in the Eigen/ subdirectory. In order
to install, just copy this Eigen/ subdirectory to your favorite location.
Thank you.
Warm regards,
Nitish
VaradJ_Intel
Good day to you
Sorry for the inconvenience, User's don't have admin privileges, so you cannot use sudo in DevCloud.
Intel DevCloud is a shared environment which comes with pre-installed validated Intel oneAPI software and complimentary packages.
As a policy we do not install custom (open source or 3rd party licensed) software to the environment.
Thank You!
Varad
VaradJ_Intel
Could you please give us an update?
Thank you!
Varad
Nitish_
Thank you.
Warm regards,
Nitish
VaradJ_Intel
Good day to you.
Glad to know that your issue is resolved.
Thanks for sharing the solution with us.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thank you!
Varad
