Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1347 Discussions
Error: Compiler Error: OpenCL kernel compile/link FAILED
sent
Hi, I am new to oneAPI and I am trying to ramping up. I installed Intel® oneAPI Base Toolkit and am able to successfully run the vector add sample program in my ubuntu system(Intel Core i5). Then I tried to compile same Vector_Add project for FPGA in emulation mode using below command.
make fpga_emu -f Makefile.fpga
At the time of compilation, I am facing below error.
dpcpp  -fintelfpga src/vector-add.cpp -o vector-add.fpga_emu -DFPGA_EMULATOR
/tmp/vector-add-d62ec6.o: file not recognized: File truncated
clang++: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
clang++: error: linker command failed with exit code 1 (use -v to see invocation)
Makefile.fpga:10: recipe for target 'vector-add.fpga_emu' failed
make: *** [vector-add.fpga_emu] Error 1
Any help on resolving this error is much appreciated.
Thanks in advance.
WILLIAM_H_Intel4
Hello!  Can you confirm that you configured your environment as described here:
https://software.intel.com/en-us/articles/getting-started-with-intel-devcloud-for-oneapi-projects
Specifically verify:
Note Compile jobs should be submitted to compute nodes labeled fpga_compile, which are dedicated to FPGA compile jobs
ChithraJ_Intel
FPGA issues are not handled here. Please ask your question in the Intel® High Level Design Forum.
