Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1713 Discussions
Error Compiling on devcloud
Chithambarash
I'm unable to compile for fpga on devcloud. I'm using interactive node.
quartus_sh_compile.log
quartus_sh_compile.logquartus_sh_compile.log
@intel @AlekhyaV_Intel @Hairul_Intel @Rahila_T_Intel
user100
Try compiling for fpga emulator instead.
AlekhyaV_Intel
Thank you for posting in Intel Communities. We are working on this issue internally and would get back to you soon with an update.
Alekhya
Chithambarash
AlekhyaV_Intel
We are sorry to let you know that there's no update from the admin team as of now. Our team is working on this internally and we would get back to you soon with an update.
Alekhya
Chithambarash
AlekhyaV_Intel
We don't have any update on this issue yet. But here's a workaround which might help you:
  1. Please put the below code in a script i.e. job.sh & run the job:
    #!/bin/bash
    export QUARTUS_ROOTDIR_OVERRIDE=/glob/development-tools/versions/oneapi/2022.3.1/intelFPGA_pro/19.2/quartus
    export QUARTUS_PRIME_192=/glob/development-tools/versions/oneapi/2022.3.1/intelFPGA_pro/19.2/quartus
    export QUARTUS_PRIME_231=/glob/development-tools/versions/intelFPGA_pro/23.1/quartus
    export PATH=$PATH:/glob/intel-python/python2/bin
    cmake . -DFPGA_DEVICE="Arria10"
    make fpga​
If this resolved your issue, make sure to accept this as a solution. This helps others with similar errors. Thank you!
Alekhya
AlekhyaV_Intel
We appreciate your patience. Regarding the errors on FPGA nodes, we apologize for the inconvenience caused & have forwarded your development experience to our relevant team. As of now, we could provide a possible workaround to compile for emulation (fast compile time, targets emulated FPGA device) using below commands:
qsub -I -l nodes=1:fpga_runtime:ppn=2 -d .
source /opt/intel/oneapi/setvars.sh
cmake ..
make fpga_emu
If this helps in resolving your issue, make sure to accept it as solution. This might help others with similar errors.
Alekhya
AlekhyaV_Intel
Has the solution provided helped? Could you please give us an update regarding this issue?
Alekhya
ThasneemV_Intel
Since we didn't hear back from you, we assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
