Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1596 Discussions
Error accessing the arria10 node on Devcloud
Devdude
I'm trying to use the arria10 FPGA to run some simulations. Upon logging in through interactive mode using the command:
qsub -I -l nodes=1:fpga_runtime:ppn=2 -d .
I get this error as soon as it finishes logging in:
/var/spool/torque/mom_priv/prologue.d//100-resetpcie.prologue: line 6: /sys/bus/pci/devices/0000:5e:00.0/remove: Permission denied
I get the same error when trying to login through the `devcloud_login` tool.
The script `100-resetpcie.prologue` tries to do the following:
#!/bin/bash
# Resetting FPGA Device
for x in `lspci | grep -i accel | grep -i intel | awk {'print $1'}`
do
echo 1 > /sys/bus/pci/devices/0000:$x/remove && sleep 1 && echo "1" > /sys/bus/pci/rescan
done
presumably to make sure the device(s) can be accessed. Trying to run this manually gives me the same error "Permission denied" to access the file.
When I try to run a synthesised bitstream (which had run before just a few days ago), it hangs forever when trying to get the device and it takes a while to kill the job.
Has anyone faced this issue before? I think a system reset is needed to properly release the board or so, but I'm not sure how to go about it.
ChrisB_Intel
Our apologies for the issues. Are you working in OpenVino or Oneapi?
Chris
ChrisB_Intel
Apologies for the issues you are running into. Are you working in OpenVino or OneAPI?
Chris
Devdude
Hi Chris, thanks for getting back to me. I'm currently working in oneAPI.
ChrisB_Intel
Thanks for clarifying, let me get the FPGA folks involved on this thread.
Chris
GRN2
You can try
qsub -I -l nodes=1:arria10:ppn=2 -d .
BoonBengT_Intel
Hi @Devdude
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Following up on the queries did you managed to try on the previous suggestion?
Please do let us know if the doubts are still here, and we would try our best to clarify.
Best Wishes
BB
BoonBengT_Intel
Hi @Devdude,
Good day, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.
Best Wishes
BB
BoonBengT_Intel
Hi @Devdude,
Greetings, unfortunately as we do not receive any further clarification on what is provided, we would assume challenge are resolved. Hence thread will no longer be monitored. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
