Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1665 Discussions
Error downloading models
pastorsoto
I am testing the pneumonia detection notebook. I want to test the product by running different experiments with different models.
I used the code snipped explorer to get the code to download a model:
#download mobilenet-ssd model using omz_downloader
MODEL_NAME='mobilenet-ssd'
OUTPUT_FOLDER ='raw_models'
!omz_downloader --name $MODEL_NAME -o $OUTPUT_FOLDER
!mkdir -p raw_models/public
!echo "\nAll files that were downloaded:"
!find ./raw_models
I got the following error message:
========== Downloading raw_models/public/mobilenet-ssd/mobilenet-ssd.prototxt
Traceback (most recent call last):
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/connection.py", line 174, in _new_conn
    conn = connection.create_connection(
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/util/connection.py", line 72, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.8/socket.py", line 914, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name or service not known
During handling of the above exception, another exception occurred:
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/connectionpool.py", line 703, in urlopen
    httplib_response = self._make_request(
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/connectionpool.py", line 386, in _make_request
    self._validate_conn(conn)
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/connectionpool.py", line 1042, in _validate_conn
    conn.connect()
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/connection.py", line 358, in connect
    self.sock = conn = self._new_conn()
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/connection.py", line 186, in _new_conn
    raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7fe08510f400>: Failed to establish a new connection: [Errno -2] Name or service not known
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/requests/adapters.py", line 489, in send
    resp = conn.urlopen(
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/connectionpool.py", line 787, in urlopen
    retries = retries.increment(
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/urllib3/util/retry.py", line 592, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /chuanqi305/MobileNet-SSD/ba00fc987b3eb0ba87bb99e89bf0298a2fd10765/MobileNetSSD_deploy.prototxt (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe08510f400>: Failed to establish a new connection: [Errno -2] Name or service not known'))
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/openvino/model_zoo/download_engine/downloader.py", line 116, in _try_download
    chunk_iterable, continue_offset = start_download(offset=progress.size, timeout=self.timeout, size=size, checksum=hasher)
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/openvino/model_zoo/download_engine/file_source.py", line 71, in start_download
    response = session.get(self.url, stream=True, timeout=timeout,
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/requests/sessions.py", line 600, in get
    return self.request("GET", url, **kwargs)
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/requests/sessions.py", line 587, in request
    resp = self.send(prep, **send_kwargs)
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/requests/sessions.py", line 701, in send
    r = adapter.send(request, **kwargs)
  File "/data/venv/openvino_2022.3.0/lib/python3.8/site-packages/requests/adapters.py", line 565, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /chuanqi305/MobileNet-SSD/ba00fc987b3eb0ba87bb99e89bf0298a2fd10765/MobileNetSSD_deploy.prototxt (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe08510f400>: Failed to establish a new connection: [Errno -2] Name or service not known'))
########## Error: Download failed
FAILED:
mobilenet-ssd
./raw_models
./raw_models/public
./raw_models/public/bert-base-ner
./raw_models/public/mobilenet-ssd
IntelSupport
Community Manager
Hi Pastorsoto,
Thanks for reaching out.
I am able to download and convert the mobilenet-ssd into OpenVINO IR format using command below:
omz_downloader --name mobilenet-ssd
omz_converter --name mobilenet-ssd
Refer below:
Please try and see if the same issue persists.
Aznie
IntelSupport
Community Manager
Hi Pastorsoto,
Refer below:
Aznie
pastorsoto
Yes. I was able to download the model. but the model is not able to make inference.
I am using the Pneumonia classification notebook on the website which has a model already in there. Then it was converted to IR files using:
# Create FP16 IR files
!mo \
--input_model model.pb \
--input_shape=[1,224,224,3] \
--data_type FP16 \
-o models/FP16/ \
--mean_values [123.75,116.28,103.58] \
--scale_values [58.395,57.12,57.375]
# Create FP32 IR files
!mo \
--data_type FP32 \
-o models/FP32/ \
# find all resulting IR files
!echo "\nAll IR files that were downloaded or created:"
!find ./models -name "*.xml" -o -name "*.bin"
So, I downloaded succesfully the model and converted into IR files using:
# Run the following cell to use the Model Optimizer to create the FP16 and FP32 model IR files
!mo \
--input_model raw_models/public/mobilenet-ssd/mobilenet-ssd.caffemodel \
--input_shape=[1,3,300,300] \
--data_type FP16 \
--output_dir models/mobilenet-ssd/FP16 \
!mo \
--data_type FP32 \
--output_dir models/mobilenet-ssd/FP32 \
!echo "\nAll IR files that were created:"
But when I run the inference it doesn't do anything on the model I donwloaded but ti does with the model.xml
%%writefile classification_pneumonia_job.sh
# Store input arguments: <output_directory> <device> <fp_precision> <input_file>
OUTPUT_FILE=$1
DEVICE=$2
FP_MODEL=$3
INPUT_FILES=("${@:4}")
# The default path for the job is the user's home directory,
#  change directory to where the files are.
echo VENV_PATH=$VENV_PATH
echo OPENVINO_RUNTIME=$OPENVINO_RUNTIME
echo INPUT_FILES="${INPUT_FILES[@]}"
echo FP_MODEL=$FP_MODEL
echo INPUT_TILE=$INPUT_FILES
echo NUM_REQS=$NUM_REQS
# Follow this order of setting up environment for openVINO 2022.1.0.553
echo "Activating a Python virtual environment from ${VENV_PATH}..."
source ${VENV_PATH}/bin/activate
echo "Activating OpenVINO variables from ${OPENVINO_RUNTIME}..."
source ${OPENVINO_RUNTIME}/setupvars.sh
cd $PBS_O_WORKDIR
# Make sure that the output directory exists.
mkdir -p $OUTPUT_FILE
# Set inference model IR files using specified precision
MODELPATH=models/mobilenet-ssd/${FP_MODEL}/mobilenet-ssd.xml
#MODELPATH=models/${FP_MODEL}/model.xml
pip3 install Pillow
# Run the pneumonia detection code
python3 classification_pneumonia.py -m $MODELPATH \
                                    -i "${INPUT_FILES[@]}" \
                                    -o $OUTPUT_FILE \
                                    -d $DEVICE
This is the last file to run the inference, when I do it for model.xml it works fine, but when I use it for mobilenet-ssd.xml it doesn't work. I tried to change the input_shape, I went to the classification_pneumonia.py file and change the target_size and none of that worked. Any idea on how to run inference with a different model than the one is already loaded?
IntelSupport
Community Manager
Hi Pastorsoto,
Please share your repository details or the source of your jupyter notebook for further checking.
Aznie
pastorsoto
This is the link of the notebook I am trying to run:
https://cdrdv2.intel.com/v1/dl/getContent/678632?explicitVersion=true
The notebook runs fine with the default seetings, however when I tried to use a different model downaloded it doesn't run the inference.
The enviroment is: Python3.8 (OpenVINO 2022.3.0)
This is the code I used:
import json
import sys
from pathlib import Path
from IPython.display import Markdown, display
from openvino.runtime import Core
sys.path.append("../utils")
#from notebook_utils import DeviceNotFoundAlert, NotebookAlert
base_model_dir = Path("model")
omz_cache_dir = Path("cache")
precision = "FP16"
precision_2 = "FP32"
# Check if an iGPU is available on this system to use with Benchmark App.
ie = Core()
gpu_available = "GPU" in ie.available_devices
print(
    f"base_model_dir: {base_model_dir}, omz_cache_dir: {omz_cache_dir}, gpu_availble: {gpu_available}"
model_name = "mobilenet-ssd"
# download the model
download_command = (
    f"omz_downloader --name {model_name} --output_dir {base_model_dir} --cache_dir {omz_cache_dir}"
display(Markdown(f"Download command: `{download_command}`"))
display(Markdown(f"Downloading {model_name}..."))
! $download_command
model_info_output = %sx omz_info_dumper --name $model_name
model_info = json.loads(model_info_output.get_nlstr())
if len(model_info) > 1:
    NotebookAlert(
        f"There are multiple IR files for the {model_name} model. The first model in the "
        "omz_info_dumper output will be used for benchmarking. Change "
        "`selected_model_info` in the cell below to select a different model from the list.",
        "warning",
model_info
selected_model_info = model_info[0]
MODEL_PATH = (
    base_model_dir
    / Path(selected_model_info["subdirectory"])
    / Path(f"{precision_2}/{selected_model_info['name']}.xml")
print(MODEL_PATH, "exists:", MODEL_PATH.exists())
!mo \
--data_type FP16 \
--mean_values [127.5,127.5,127.5] \
--scale_values [0.007843,0.007843,0.007843]
!mo \
--data_type FP32 \
OUTPUT_FILE=$1
DEVICE=$2
FP_MODEL=$3
INPUT_FILE="$4"
echo INPUT_FILE=$INPUT_FILE
cd $PBS_O_WORKDIR
MODELPATH=models/${FP_MODEL}/mobilenet-ssd.xml
pip3 install Pillow
                                    -i "$INPUT_FILE" \
                                    -o $OUTPUT_FILE \
                                    -d $DEVICE
My guess is that it could be something related to the input shape but I am not really sure
JesusE_Intel
Hi pastorsoto,
The Pneumonia Detection sample was put together for this specific model. Using a different model may require many changes to the OpenVINO inference code as the model architecture may be different. Take a look at the Jupyter notebook, it contains some background information about the specific model. There are other OpenVINO samples that handle mobile-ssd architectures. Take a look at this sample code:
https://docs.openvino.ai/latest/omz_demos_single_human_pose_estimation_demo_python.html#doxid-omz-demos-single-human-pose-estimation-demo-python
Jesus
JesusE_Intel
