Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
Error enumerating AFCs: no driver available
ChongzhouFang
I am using OpenCL on an Aria 10 node and have generated an .aocx file. However, when I try to program the FPGA by using:
aocl program acl0 xxx.aocx
This error message pops out:
Error parsing device name '����'
aocl program: Running program from /opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
Error programming device
aocl program: Program failed.
I ran aocl diagnose command later and saw this error message in BSP Diagnostics:
BSP Diagnostics
I am wondering what may be the cause of this, since previously everything works fine and I didn't change the .aocx file.
Thank you!
AthiraM_Intel
Could you please confirm whether you are using DevCloud for fpga?
Also share the node number in which you got this error and the screenshot for the same.
ChongzhouFang
Thank you for the reply.
I am using node s005-n007. According to the devcloud_login options this should be a node supporting Arria 10 compiling and programming.
The screenshot is attached:
AthiraM_Intel
Thank you for sharing the details and screenshot. We are working on this internally.
ChongzhouFang
Thank you for taking care of this!
Just a quick follow-up on this issue:
Currently, are there any workarounds regarding this issue, if I still want to run my accelerators on Arria 10 FPGAs?
Thank you!
AthiraM_Intel
Our sincere apologies for the delay. We will update you once we find the resolution.
AthiraM_Intel
Apologies for the delay.
The issue has been resolved. Could you please check from your side and let us know.
ChongzhouFang
Thank you very much for your work! I confirm that it works.
AthiraM_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
