Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1637 Discussions
Error enumerating AFCs: no driver available
ChongzhouFang
I am using OpenCL on an Aria 10 node and have generated an .aocx file. However, when I try to program the FPGA by using:
aocl program acl0 xxx.aocx
This error message pops out:
Error parsing device name '����'
aocl program: Running program from /opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
Error programming device
aocl program: Program failed.
This happened a few months ago and it was fixed later (https://community.intel.com/t5/Intel-DevCloud/Error-enumerating-AFCs-no-driver-available/m-p/1459733/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExFTVIwOFhYTTMzN0Q0fDE0NTk3MzN8U1VCU0NSSVBUSU9OU3xoSw). However, this error message showed up again in our recent usage.
I ran aocl diagnose command later and saw this error message in BSP Diagnostics:
BSP Diagnostics
This happens on both nodes s005-n007 and s005-n004.
The corresponding screenshot is attached.
Please let me know what may be the cause of this. Thank you!
Rahila_T_Intel
Thanks for posting in Intel communities.
We tried to reproduce the issue from our end, but it is working fine
We sincerely apologize for the inconvenience caused. We have tested and verified the aocl diagnose is working fine on both nodes (s005-n007 and s005-n004). PFA screenshot.
Can you please check in on your side, and let us know if you see any issues.
ChongzhouFang
Thanks for replying.
I tried again and it is now working. For some reason that problem occurred on 3/10.
Please close this thread. Thank you!
Rahila_T_Intel
Glad to know that your issue is resolved.
Make sure to accept the solution. This would help others with similar issue.
If you need further assistance, please post a new question as this thread will no longer be monitored by Intel.
