Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Error from STDIN.e( ModuleNotFoundError: No module named 'tornado')
Tchouanga__Franck
File "violenceData03.py", line 174 cd $PBS_O_WORKDIR ^ SyntaxError: invalid syntax Traceback (most recent call last): File "violenceData03.py", line 16, in <module> import cv2 ModuleNotFoundError: No module named 'cv2' Traceback (most recent call last): File "violenceData03.py", line 16, in <module> import cv2 ModuleNotFoundError: No module named 'cv2' Traceback (most recent call last): File "violenceData03.py", line 16, in <module> import cv2 ModuleNotFoundError: No module named 'cv2' Traceback (most recent call last): File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/backends/backend_webagg.py", line 26, in <module> import tornado ModuleNotFoundError: No module named 'tornado' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "violenceData03.py", line 12, in <module> import matplotlib.pyplot as plt File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/pyplot.py", line 2349, in <module> switch_backend(rcParams["backend"]) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/pyplot.py", line 221, in switch_backend backend_mod = importlib.import_module(backend_name) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/importlib/__init__.py", line 127, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/backends/backend_webagg.py", line 28, in <module> raise RuntimeError("The WebAgg backend requires Tornado.") RuntimeError: The WebAgg backend requires Tornado. Traceback (most recent call last): File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/backends/backend_webagg.py", line 26, in <module> import tornado ModuleNotFoundError: No module named 'tornado' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "violenceData03.py", line 12, in <module> import matplotlib.pyplot as plt File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/pyplot.py", line 2349, in <module> switch_backend(rcParams["backend"]) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/pyplot.py", line 221, in switch_backend backend_mod = importlib.import_module(backend_name) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/importlib/__init__.py", line 127, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/backends/backend_webagg.py", line 28, in <module> raise RuntimeError("The WebAgg backend requires Tornado.") RuntimeError: The WebAgg backend requires Tornado. Traceback (most recent call last): File "violenceData03.py", line 9, in <module> import tornado ModuleNotFoundError: No module named 'tornado' Traceback (most recent call last): File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/backends/backend_webagg.py", line 26, in <module> import tornado ModuleNotFoundError: No module named 'tornado' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "violenceData03.py", line 11, in <module> import matplotlib.pyplot as plt File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/pyplot.py", line 2349, in <module> switch_backend(rcParams["backend"]) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/pyplot.py", line 221, in switch_backend backend_mod = importlib.import_module(backend_name) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/importlib/__init__.py", line 127, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/lib/python3.7/site-packages/matplotlib/backends/backend_webagg.py", line 28, in <module> raise RuntimeError("The WebAgg backend requires Tornado.") RuntimeError: The WebAgg backend requires Tornado. Traceback (most recent call last): File "violenceData03.py", line 9, in <module> import tornado ModuleNotFoundError: No module named 'tornado'
please help[ how can I fix thuis
ArunJ_Intel
Hi Franck
Could you please try creating separate conda environment with python version as per your requirement and do opencv installation.
eg:
conda create -n myenv python=3.6
source activate myenv
pip install opencv-python
Could you try out these steps and and see if you are able to import cv2 without issues in this newly created environment.
Arun Jose
ArunJ_Intel
Hey Franck,
Did the provided solution help? . Could you please provide an update on this.
Arun Jose
Tchouanga__Franck
yes thanks very much. I will try out and let you know
ArunJ_Intel
Hey Franck,
Hope you have tried out the steps we provided. Could you please confirm if your issue is resolved.
Arun Jose
ArunJ_Intel
Hey  Franck,
We are closing this case assuming the solution provided helps. Please feel free to raise a new thread in case of further issues
Arun Jose
