Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1517 Discussions
Error in oneapi-cli command operation on devcloud.
CABELO
Innovator
In the attached video, I demonstrate the navigation error in the oneapi-cli command menu on the devcloud platform.
https://vimeo.com/manage/videos/740630782
AthiraM_Intel
The issue is because you are trying the oneapi-cli command from login node. You can run the same command from the compute node without any issue.
Login to the compute node with the below command:
qsub -I
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
CABELO
Innovator
Thanks for the quick response. I know that in interactive mode there is no bug. But as it always worked in login mode I reported.
With the qsub -I command the command works fine.
Thank you very much.
AthiraM_Intel
For your information, login node uses a lightweight general-purpose processor. Login nodes should not be used for development or execution of programs. It is an interface node that helps to connect or submit jobs to compute nodes.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
