Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1665 Discussions
Error make fpga!!!!
ruma
Hello!!
Can you help me please!!
When I compile and execute the example ac_fixed in FPGA device with the instruction "make fpga", I have the next error. I put the image. How I can solucionate, please???
u114512@s001-n061:~/oneAPI-samples-master_2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/ac_fixed/build$ make fpga
Scanning dependencies of target ac_fixed.fpga
[ 50%] Building CXX object src/CMakeFiles/ac_fixed.fpga.dir/ac_fixed.cpp.o
[100%] Linking CXX executable ../ac_fixed.fpga
warning: -reuse-exe file '/home/u114512/oneAPI-samples-master_2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/ac_fixed/build/ac_fixed.fpga' not found; ignored
aoc: Compiling for FPGA. This process may take several hours to complete. Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets. If the reports indicate performance targets are not being met, code edits may be required. Please refer to the oneAPI FPGA Optimization Guide for information on performance tuning applications for FPGAs.
Error: The board package being used only supports report generation/emulation/runtime, please use the board package shipped in the FPGA addon instead.
Error: Exiting.
llvm-foreach:
icpx: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
make[3]: *** [src/CMakeFiles/ac_fixed.fpga.dir/build.make:84: ac_fixed.fpga] Error 1
make[2]: *** [CMakeFiles/Makefile2:129: src/CMakeFiles/ac_fixed.fpga.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:109: src/CMakeFiles/fpga.dir/rule] Error 2
make: *** [Makefile:118: fpga] Error 2
Best regards.-
Ruma
Rahila_T_Intel
Sorry for the inconvenience caused and thanks for reporting the same.
We have reported this issue to the development team, and it should be fixed soon.
Rahila_T_Intel
Thanks for posting in Intel communities.
We could see that there is a similar case which you posted, https://community.intel.com/t5/Intel-DevCloud/Error-make-report/m-p/1453474 , where the error is similar.
We have already informed the admin team regarding this. They are working on it. Once it is resolved we hope that this particular issue will also be resolved.
Rahila_T_Intel
We have not heard back from you. Could you please give an update?
ruma
Hello Rahila
I have the same error, Can you help me? This error is when I want to compile and execute wathever example in arria 10 or stratix 10. The emulation is good but in the device have error. This is the process step by step:
1.- ruben@DESKTOP-FGKG264:~$ ssh devcloud
2.- u114512@login-2:~$ qsub -I -l walltime=24:00:00 -l nodes=1:fpga_runtime:ppn=2 -d .
3.- u114512@s001-n143:~$ aocl diagnose
4.- u114512@s001-n143:~$ cd oneAPI-samples-2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/
5.- u114512@s001-n143:~/oneAPI-samples-2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/ac_fixed$ cd build/
u114512@s001-n143:~/oneAPI-samples-2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/ac_fixed/build$ cmake ..
6.- u114512@s001-n143:~/oneAPI-samples-2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/ac_fixed/build$ make fpga_emu
[100%] Built target ac_fixed.fpga_emu
[100%] Built target fpga_emu
7.- u114512@s001-n143:~/oneAPI-samples-2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/ac_fixed/build$ ./ac_fixed.fpga_emu
8.-
[ 50%] Linking CXX executable ../ac_fixed.fpga
warning: -reuse-exe file '/home/u114512/oneAPI-samples-2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/ac_fixed/build/ac_fixed.fpga' not found; ignored
Error: Exiting.
llvm-foreach:
src/CMakeFiles/ac_fixed.fpga.dir/build.make:94: recipe for target 'ac_fixed.fpga' failed
make[3]: *** [ac_fixed.fpga] Error 1
CMakeFiles/Makefile2:93: recipe for target 'src/CMakeFiles/ac_fixed.fpga.dir/all' failed
make[2]: *** [src/CMakeFiles/ac_fixed.fpga.dir/all] Error 2
CMakeFiles/Makefile2:302: recipe for target 'src/CMakeFiles/fpga.dir/rule' failed
make[1]: *** [src/CMakeFiles/fpga.dir/rule] Error 2
Makefile:196: recipe for target 'fpga' failed
make: *** [fpga] Error 2
Atachment pictures, hope me help please...
Best regards.-
Rubén
irpeitzsch
Hi, I am not the original poster, but I am still having this problem. Are there any updates on the progress of fixing this issue?
Rahila_T_Intel
ruma
Dear Rahila
Thanks a lot for all, and the development team too. This issue is fixed.
Best regards.-
Rubén
wan1
Hi ruben,
I met the same problem, could you please share how to solve it?
ruma
Hello Wan
You need to follow the next steps:
8.-
Rahila_T_Intel
Thanks for accepting our solution.
Glad to know that your issue is resolved. If you need further assistance, please post a new question as this thread will no longer be monitored by Intel.
