Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1596 Discussions
Error make report
ruma
Hello!!
Can you help me please!!
When I compile and execute the example loop unroll and want to generate report, I have the next error. I put the image. How can solucionate???
u114512@s001-n088:~/oneAPI-samples-2023/DirectProgramming/C++SYCL_FPGA/Tutorials/Features/loop_unroll_/build$ make report
[ 50%] Linking CXX executable ../loop_unroll_report.a
Error: Could not find its path for the provided board package name: "intel_arria10_pac". Please make sure the board package is under $INTEL_FPGA_ROOT/board or $INTELFPGAOCLSDKROOT/board, or specify the full path for the board package
llvm-foreach:
icpx: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
src/CMakeFiles/loop_unroll_report.a.dir/build.make:94: recipe for target 'loop_unroll_report.a' failed
make[3]: *** [loop_unroll_report.a] Error 1
CMakeFiles/Makefile2:328: recipe for target 'src/CMakeFiles/loop_unroll_report.a.dir/all' failed
make[2]: *** [src/CMakeFiles/loop_unroll_report.a.dir/all] Error 2
CMakeFiles/Makefile2:271: recipe for target 'src/CMakeFiles/report.dir/rule' failed
make[1]: *** [src/CMakeFiles/report.dir/rule] Error 2
Makefile:183: recipe for target 'report' failed
make: *** [report] Error 2
Best regards!!
Ruma
JaideepK_Intel
Good day to you.
We fixed FPGA issues, could you please run the samples and let us know.
"make report" works fine, attaching screenshot for your reference.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
We were able to reproduce your issue from our end and we are working on this internally and get back to you with an update.
Jaideep
JaideepK_Intel
Good day to you.
Jaideep
JaideepK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
