Hello, I keep getting the following error when I try to run any job from my Jupyter Notebook in the DevCloud
Unable to init server: Could not connect: Connection refused
(frame:3558): Gtk-WARNING **: 23:43:02.292: cannot open display:
File "/etc/collectd/influxdbSender.py", line 580, in <module>
sys.exit(main() or 0)
File "/etc/collectd/influxdbSender.py", line 466, in main
"applicationName": applicationName,
UnboundLocalError: local variable 'applicationName' referenced before assignment
This error occurs when I use the cv2.imshow function on the Jupyter Notebook. Please can anyone help me with this issue.
Hi Elcid,
Please refer to following article to solve the jupyter notebook and cv2.imshow issue:
Priyanka
Hello Elcid,
The following error message:
... should now be fixed. We think this error was harmless, and likely unrelated to the cv2.imshow issue, but if this error message persists, please let us know and we'll investigate.
Jason
Python has lexical scoping by default, which means that although an enclosed scope can access values in its enclosing scope, it cannot modify them (unless they're declared global with the global keyword). A closure binds values in the enclosing environment to names in the local environment. The local environment can then use the bound value, and even reassign that name to something else, but it can't modify the binding in the enclosing environment. UnboundLocalError happend because when python sees an assignment inside a function then it considers that variable as local variable and will not fetch its value from enclosing or global scope when we execute the function. To modify a global variable inside a function, you must use the global keyword.
