I am trying to follow these steps below but getting an error message in the Cygwin.
Please advise!
Error message.
We tried to connect to DevCloud from Cygwin and didn’t find any issues.
If you are behind proxy use following command:
ssh devloud.proxy
And also could you again try configuring with manual steps provided and make sure Host devcloud is there in the config file.
steps to follow:
https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/
You can find config file inside ~<installed directory>/.ssh/config
Abhijeet
Is your issue resolved? Could you please give us an update?
Abhijeet
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel
Abhijeet
