Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
Execute FPGA openCL sample in Devcloud
yyjpro
I want to test the FPGA OpenCL code on devcloud, but I encountered the problem that the emulation compilation result does not match the hardware compilation result. Here is my sample code.
Here is the flow of my FPGA hardware host compilation, and I referenced this post for the compilation:
dpcpp helloworld.c -o helloworld.out -lOpenCL -lm -I/opt/intel/inteloneapi/compiler/latest/linux/include/sycl/
 Kernel compilation is in the form of batch job:
#!/bin/bash
aoc -c helloworld.cl -o helloworld.aocx
 which submitted to the FPGA compilation node:
qsub -l nodes=1:fpga_compile:ppn=2 -d . job.sh
run on the execution node:
qsub -I -l nodes=1:fpga_runtime:arria10:ppn=2 -d .
 Execution gives the following error result:
But the emulator's result is correct:
I tried to compile and execute using a different FPGA node, but each time I got a different error result.
source /data/intel_fpga/devcloudLoginToolSetup.sh
devcloud_login
So what's the reason, thanks!
BoonBengT_Intel
Hi @yyjpro,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
We did managed to saw the mention behavior, and do notice that the kernel compilation are having some error where removing the -c param fixed it.
Allow us to check on the code to understand further, and just to align, what is the code trying to do here?
Hope to hear from you soon.
Best Wishes
BB
yyjpro
Hi @BoonBengT_Intel ,
Thank you for your reply.
I want to learn and test oneAPI FPGA DPC++ project. I think OpenCL for FPGA project can help me better understand DPC++, so I wrote some FPGA OpenCL programs to test in DevCloud, but I encountered the above problems.
Thank you for helping me check this problem. And I removed the - c option and still output the following wrong results.
BoonBengT_Intel
Hi @yyjpro,
Apologies for the delayed in response, as looking through the code mu guess is it might not be accordingly to the required guideline.
For that I would suggest to look into the example below for OpenCL with FPGA on devcloud to compile and run it:
- https://github.com/intel/FPGA-Devcloud/tree/master/main/QuickStartGuides/OpenCL_Program_PAC_Quickstart/Stratix%2010
Hope that clarify.
Best Wishes
BB
BoonBengT_Intel
Hi @yyjpro,
Good day, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.
Best Wishes
BB
yyjpro
Hi @BoonBengT_Intel
I think I can solve this problem on other servers, so there is no problem. Thanks!
BoonBengT_Intel
Hi @yyjpro,
Great! Good to know that it is working now, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
