Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1474 Discussions
Execution of serial code on 1 physical core of Gold 6128 and E-2176G processors on the devcloud
Oluwatosin
I need to get the execution time of a serial code on 1 physical core of the gold 6128 and E-2176G processors. How do I request for 1 physical core with the qsub command. I have tried using (Gold 6128) :
qsub -I -l ncpus=1,
qsub -I -l procs=1,
but I still obtain same timings as when I request using: qsub -I -l nodes=1:ppn=2
Thank you.
Kind regards
Oluwatosin.
RaeesaM_Intel
Thanks for reaching out to us .
We are checking on this issue internally and will get back to you soon with the updates.
Raeesa
Oluwatosin
Alright, thank you!
RaeesaM_Intel
Could you please try the below qsub command to request for 1 physical core :
qsub -l nodes=1:ppn=1
which gives us an allocation of 1 core on one node.
Let us know the updates.
Thanks and Regards,
Raeesa
Oluwatosin
I get this:
ERROR in qsub arguments:
Compute nodes in this cabinet are configured with 2 slots per node,
but you included the argument "-l nodes=1:ppn=1", which results in 1 slot per node.
With this argument, your application will not have full control over its node(s).
Please run with "-l nodes=1:ppn=2" instead.
RaeesaM_Intel
We are checking on this issue internally. Please give us some time, we will get back to you with the updates.
Thanks and Regards,
Raeesa
RaeesaM_Intel
Sorry for the delayed response. We were checking from our end regarding requesting a single physical core and tried different methods from our end but unfortunately requesting 1 physical core is not possible. Lets us know if you have any further queries. Can we discontinue monitoring this thread ?
Raeesa
Oluwatosin
Yes, you can discontinue monitoring the thread. Thank you.
RaeesaM_Intel
Thank you for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Raeesa
