since today I encouter error when compiling for the Arria10 PAC. The build runs fine at the beginning, but crashes near the end of it.
The .o file of the job gives no real hints what's going wrong:
aoc: Compiling for FPGA. This process may take several hours to complete. Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets. If the reports indicate performance targets are not being met, code edits may be required. Please refer to the oneAPI FPGA Optimization Guide for information on performance tuning applications for FPGAs.
Error (23035): Tcl error:
Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings
The .e file neither:
For more details, full Quartus compile output can be found in files quartuserr.tmp and quartus_sh_compile.log.
Error: Compiler Error, not able to generate hardware
llvm-foreach:
icpx: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
make[3]: *** [cuda/level2/particlefilter/CMakeFiles/particlefilterLib.fpga.dir/build.make:100: cuda/level2/particlefilter/particlefilterLib.fpga] Error 1
make[2]: *** [CMakeFiles/Makefile2:3295: cuda/level2/particlefilter/CMakeFiles/particlefilterLib.fpga.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:2951: cuda/level2/particlefilter/CMakeFiles/particlefilterLib_fpga.dir/rule] Error 2
make: *** [Makefile:1236: particlefilterLib_fpga] Error 2
Here a short snippet of the quartus log (complete file as attachement):
Info: Quartus Prime Shell was successful. 0 errors, 237 warnings
Info: Peak virtual memory: 3474 megabytes
Info: Processing ended: Sat Dec 17 05:41:47 2022
Info: Elapsed time: 00:01:38
run.sh: PLL_METADATA/PLL_METADATA_FILE is:
clock-frequency-low:195 clock-frequency-high:390
ERROR: [Errno 2] No such file or directory: './output_files/afu_import.green_region.rbf'
ERROR: packager tool failed to create .gbs file.
Info: *******************************************************************
Info: Running Quartus Prime Shell
Info: Version 19.2.0 Build 57 06/24/2019 SJ Pro Edition
Info: Copyright (C) 2019 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Sat Dec 17 04:36:27 2022
Info: Command: quartus_sh -t build/entry.tcl import
Info: Quartus(args): import
Info: Using INI file /home/u153009/tmp/main-4a28c3-d5e0be/quartus.ini
Info: Compiling revision import
while executing
"qexec "bash build/run.sh $revision_name""
("default" arm line 9)
invoked from within
"switch $tcl_platform(platform) {
windows {
post_message -type error "Full compiles to generate hardware for the FPGA are available on supported ..."
(file "build/entry.tcl" line 36)
Error: Peak virtual memory: 979 megabytes
Error: Processing ended: Sat Dec 17 05:41:49 2022
Error: Elapsed time: 01:05:22
Is something wrong with the Quartus-Setup on IntelDevcloud?
Best regards and thanks in advance for your help,
Christoph
- Tags:
- +66623913162
- +66648868871
- 196 จำปาทอง
- 367 จำปาทอง
- choochat118866@gmail.com
- CHOOCHATJUMPATHONG
- สมศักดิ์ จำปาทอง
- สุข จำปาทอง
- สุภาพร จำปาทอง
- เกษม จำปาทอง
- เหลี่ยม จำปาทอง
Small update: The complete error message in the entry.tcl is the following:
"Full compiles to generate hardware for the FPGA are available on supported Linux platforms only. Please add -rtl to your invocation of aoc to compile without building hardware. Otherwise please run your compile on a supported Linux distribution."
So there definitely seems to be something wrong here.
Christoph
Thank you for posting in Intel Communities. Could you please provide us your Sample Reproducer and steps to reproduce your issue so that we can try reproducing your issue from our end?
Alekhya
Hey Alekhya,
this occur on all builds. I also tried the GettingStarted/Fpga_Compile example from the OneApi Samples github repo - the error occurs also there.
(Also when compiling the tutorial, I noticed there is something wrong with your header-files. I needed to remove
and the default exception-handler.)
u153009@s001-n068:~/oneAPI-samples/DirectProgramming/DPC++FPGA/Tutorials/GettingStarted/fpga_compile/build$ make fpga
Scanning dependencies of target fpga_compile.fpga
[ 50%] Building CXX object src/CMakeFiles/fpga_compile.fpga.dir/fpga_compile.cpp.o
/home/u153009/oneAPI-samples/DirectProgramming/DPC++FPGA/Tutorials/GettingStarted/fpga_compile/src/fpga_compile.cpp:50:11: warning: unused type alias 'T' [-Wunused-local-typedef]
using T = int;
1 warning generated.
using T = int;
[100%] Linking CXX executable ../fpga_compile.fpga
llvm-foreach:
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
make[3]: *** [src/CMakeFiles/fpga_compile.fpga.dir/build.make:84: fpga_compile.fpga] Error 1
make[2]: *** [CMakeFiles/Makefile2:100: src/CMakeFiles/fpga_compile.fpga.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:161: src/CMakeFiles/fpga.dir/rule] Error 2
make: *** [Makefile:144: fpga] Error 2
I am also having the same issue. The project folder is created as well as the reports, but no executable is generated and when I check the compile log I get the same situation. I've tried compiling multiple files so I don't think the problem is a bug in my code. I added a copy of the compile log as an annex.
Any updates to this issue? Would be great if this could be fixed before the holidays...
Hello, is there any update for this ? I am also getting the same error messages for all the arria10 oneapi nodes for my own project and also for the default examples from the github DPC++FPGA folder
Hi All,
We could reproduce your issue. We are working on this internally. We will get back to you soon with an update.
Alekhya
Hey @AlekhyaV_Intel ,
are there any updates to this? Or any work around so I can start working again on my projects using the Arria10 FPGA? Would be really great if this could be fixed soon, as I have some deadlines to face during my thesis I currently work on.
Christoph
The compilation is still not working for Arria10 and Stratix10 FPGAs I have tried s001-n142 and this is the error still. This issue started when the oneAPI is upgraded to 2023 version
llvm-foreach:
Hey all,
Any updates to this? I tried loading older OneApi versions but still the same error. FPGA builds are now broken for nearly 3 weeks and I really need to continue my compiles for my master-thesis...
Isn't there any temporary workaround or better: Just a rollback of the quartus-version on the compile-nodes?
Thanks in advance,
Christoph
I'm having the same problem. Everything works fine for emulator or to get the reports, but it fails when I try to use the FPGA. I can't even compile the given examples.
Any solutions?
Hey Sue,
I have no solutions, even on the arria10-nodes this error occurs mostly. I am unable to compile for nearly a month now.
Just hoping that the Intel representatives don't ignore this thread for another month...
Hi All,
Our sincere apologies for the delay. We will update you once we find the resolution.
Alekhya
I am running into the same issue with both the dpcpp and icpx -fsycl driver. Hopefully, this can be fixed soon.
Cheers,
Rob
Hello.
I would like to add that I have been having this issue since November. I work with OpenCL instead of DPC++, and I am facing equivalent problems and error messages. I made two community posts about it back when I started having problems; one for Arria 10 and the other for Stratix 10 (at first I thought they were different issues).
For completeness, the links to those community posts are:
In my case, when compiling for Stratix 10, I recurringly see the following error message in addition to the build/entry.tcl one:
Error (16556): The synthesis RTL for ip/ddr_board/ddr_board_acl_memory_bank_divider_1.ip has not been generated. Generate the synthesis RTL form within Platform Designer.
Maybe it provides more insight into the issue.
I apologize for not seeing this community post earlier so I could add my experience and help with the solutions. I thought my posts were the only ones about this topic (as they were for about a month), so I eventually stopped looking for the solution in other posts.
Thanks for the help. I hope the issue is resolved soon.
Manuel
Hello@hareesh
Seems like there is already another post (this one) reporting my issue, and there are people already working on a solution for it. So I won't be creating a new post/case.
Please, if you could before closing my post/case, indicate that this post is reporting the same issue, and that it is only closed because it is a duplicate, not because it was solved.
Is there any update to this problem ? I couldn't work on my project still and It's more than a month now!
