Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1716 Discussions
FPGA DevCloud: Is it possible to use AFU simulation enrionment (ASE)
agond2
I have synthesized the example designs from the quickstart guide for the RTL-AFU:
https://github.com/intel/FPGA-Devcloud/blob/master/main/QuickStartGuides/RTL_AFU_Program_PAC_Quickstart/Stratix10/README.md
The quickstart guide for RTL-AFU does mention that simulation (ASE) is not supported but as the last commit on that guide was made 3 years ago, I was wondering if anything has changed with respect to the availability of ASE on DevCloud.
I noticed QuestaSim is installed in the latest version of Quartus on DevCloud
u@s005-n005:/glob/development-tools/versions/intelFPGA_pro/23.1$ ls
devdata  devices  gcc  hld  hls  ip  licenses  logs  nios2eds  niosv  qsys  quartus  questa_fe  questa_fse  riscfree  syscon  uninstall
Is there a way to simulate the RTL-AFU on DevCloud using Questa(or any other simulator)?
If so, I would appreciate any feedback on how I can simulate the RTL-AFU designs on DevCloud
-Thanks,
Atharva Gondhalekar
DiyaN_Intel
We are investigating your issue at our end and working on this internally.
We will get back to you with an update soon.
Diya
DiyaN_Intel
Please find this document attached about the "Questa Intel® FPGA Edition Simulation User Guide".
Hope this will help you to simulate the RTL-AFU on DevCloud using Questa.
If this resolves your issue, make sure to accept this as a solution.
This would help others with similar issues. Thank you!
Diya
DiyaN_Intel
Good day to you.
We have not heard back from you.
Is your issue resolved with the above solution?
This would help others with similar issue. Thank you!
Thanks and Regards,
Diya
DiyaN_Intel
Hi ,
Good day to you.
We assume that your issue is resolved with the solution provided.
This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Diya
NavaneethM
Any luck running ASE simulation on devcloud?
Thanks!!
