Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1717 Discussions
FPGA Hardware Compile Issue for S10 PAC
VR2016
I'm looking to get a hardware compile for S10 PAC for a design that works in Emulation, but the build results in an error. Wondering if I can get some help in figuring out the issue here.  Don't think it's the memory issue required for S10 compile, since the server had around 190GB of memory.
Error: Failed to open quartus_sh_compile.log
llvm-foreach:
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
make[3]: *** [src/CMakeFiles/ac_int.fpga.dir/build.make:84: ac_int.fpga] Error 1
make[2]: *** [CMakeFiles/Makefile2:127: src/CMakeFiles/ac_int.fpga.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:107: src/CMakeFiles/fpga.dir/rule] Error 2
make: *** [Makefile:118: fpga] Error 2
# Job ID: 1982788.v-qsvr-1.aidevcloud
# User: u164770
# Resources: neednodes=1:fpga_compile:ppn=2,nodes=1:fpga_compile:ppn=2,walltime=24:00:00
server used : s001-n053
Compile Command:
qsub -l walltime=24:00:00 -l nodes=1:fpga_compile:ppn=2 -d . build_fpga_hw.sh
build_fpga_hw.sh:
source /opt/intel/inteloneapi/setvars.sh
make fpga
-VR
AlekhyaV_Intel
Thank you for posting in Intel Communities. Could you please let us know which sample you're trying to run?
We tried FPGA Compile sample on DevCloud and we did not get any error while compiling.
Before running that .sh script, could you please try the below command in the fpga_compile node and see if the issue still persists?
cmake .. -DFPGA_BOARD=intel_s10sx_pac:pac_s10
Alekhya
AlekhyaV_Intel
We have not heard back from you. Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
Hi @VR2016 ,
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
