Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1716 Discussions
Failed to log in devcloud using ssh
hueyline
I followed the guide to connect to DevCloud from Windows. However, I encountered connection closed by UNKNOWN 65535 when trying to "ssh devcloud.proxy". Any idea?
RajashekarK_Intel
Hi, Thanks for posting in Intel Communities.
One possible issue might be, If you are not connected to proxy network and trying to ssh via proxy. Please try the below workaround.
1. Either try to connect without proxy using, $> ssh devcloud.
2. Connect to proxy and issue the command, $> ssh devcloud.proxy.
If the connection is still not established, Requesting you to share the config file in order to debug your issue further.
Rajashekar
RajashekarK_Intel
Hi, Good day to you.
We have not heard back from you. Is your issue resolved with the above information?
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Rajashekar
RajashekarK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Rajashekar
