Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1517 Discussions
Failure in executing the own AI model using IR format
Wen_Jie
Good day everyone
I am doing my project using an AI model to detect the car plate in a video.
I created a model, optimized it, and generated 3 files (plate_detection.bin, plate_detection.xml, plate_detection.mapping).
However when I look into the .xml file content and compare it with the samples inside the DevCloud for edge (Reference-samples/iot-devcloud/openvino-dev-latest/developer-samples/python/safety-gear-detection-python/models/mobilenet-ssd/FP16/mobilenet-ssd.xml).
The figure below shows the content of .xml files(left: sample in devcloud, right: own project)
The contents are a bit different.
This resulted in unsuccessfully compiled model as shown in the figure below (left: sample in devcloud, right: own project):
Is this the reason causing the failure to execute own .xml file?
JesusE_Intel
Hi Wen Jie,
Thank you for sending the model and video file over! I was able to inference the model and obtain valid detections. I noticed the model you shared is based on the yolo-v4-tiny architecture. We have a yolo-v4-tiny sample on Intel Developer Cloud for the Edge that requires minimal changes to run your model and video.
The sample can be found here: Tiny YOLO* V4 Object Detection
To run with your files:
I uploaded your model (.bin/.xml, not .mapping) and video file to the Reference-samples/iot-devcloud/openvino-dev-latest/developer-samples/python/tiny-yolo-v4-python directory.
I changed the following in 1.5.4.1. Configure input:
# Set the path to the input video to use for the rest of this sample
#InputVideo = "classroom.mp4"
InputVideo = "car.mp4"
I also changed the following in 1.6.0.1. Create the job file
# Set inference model IR files using specified precision
#MODELPATH=models/tinyyolov4/${FP_MODEL}/yolov4-tiny.xml
MODELPATH=plate_detection.xml
# Run the Tiny YOLO V4 object detection code
python3 object_detection_demo_yolov4_async.py -m $MODELPATH \
  -i $INPUT_FILE \
  -o $OUTPUT_FILE \
  -d $DEVICE \
  -t $THRESHOLD \
  -nireq $NUMREQUEST \
  -nstreams $NUMSTREAMS \
  -no_show #\
  #--labels $LABELS
Please note that in the python3 command, I only commented out the labels argument and removed the forward slash in the previous line.
Could you give that a try and let me know if it works for you?
Jesus
JesusE_Intel
Hi Wen_Jie,
Thanks for reaching out, I don't believe the issue is related to your model. I think the sample failed to open the video file, the sample runs inference on a file located in /data/reference-sample-data/safety-gear-detection/Safety_Full_Hat_and_Vest.mp4. However, in your screenshot it's trying to open /data/carplate_video.mp4. Can you confirm the file is located in the correct location?
Would it be possible for you to share your model and video input for me to test on my end?
Jesus
Wen_Jie
Hi JesusE_Intel
Ya, sure. How can the sharing be done?
JesusE_Intel
Hi Wen_Jie,
I sent you a private note to your email. Please check your inbox and let me know if you don't receive it.
Jesus
Wen_Jie
Hi Jesus
I have replied to the email you sent.
Do you receive the files?
Wen Jie
JesusE_Intel
Hi Wen Jie,
  -i $INPUT_FILE \
  -o $OUTPUT_FILE \
  -d $DEVICE \
  -t $THRESHOLD \
  -no_show #\
  #--labels $LABELS
Jesus
Wen_Jie
Hi Jesus
I had try it using the method you suggested and it is successful.
Thank you very much.
Wen Jie
JesusE_Intel
Great! If you need any additional information, please submit a new question as this thread will no longer be monitored.
