Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1521 Discussions
Following the Devcloud Access Instructions
Katerina
Good afternoon!
I have recently had a problem with Downloading an SSH key (3.3) while trying to perform steps from Devcloud Access Instructions (https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions).
The fact is that clicking on the following link to access the Connect website: https://devcloud.intel.com/fpga/connect/# transfers me to the page where I can choose “Sign in” or "Register".
 I have already created an Intel DevCloud account and received the e-mail about its successful activation. So, when I click “Sign in” the following page is displayed:
However,  as it can be observed from the Instructions, I should see the page in the picture below:
Even if I click "Enroll Now" in the previous picture I can not see the necessary page.
Could you, please, help me with this 3.3 step of connecting to Intel FPGA DevCloud?
Thank you!
Katerina
GRN2
FPGA Devcloud is subset of oneAPI Devcloud.
So, you can use base DevCloud for oneAPI to submit tasks on FPGA nodes.
GRN2
Katerina
Good afternoon! Thank You very much for such a quick answer!
Now I'm trying to follow the Instructions from this page (Connect to DevCloud -- Cygwin on Windows): https://devcloud.intel.com/oneapi/get_started/opencl/
Unfortunately, I have been stopped at the point of "Getting X2Go" (1.4) where I follow the link to download and install X2Go, but clicking on the place "mswin" does not start downloading. Could You, please, help me to complete this step of the instruction: where can I get the neccessary .exe file?
I have already tried to download such a file from another section of the site and install it, but when working with command prompt, command 'systemctl status x2goserve' still gives the following:
Katerina
Katerina
Katerina
GRN2
Sorry, I don't understand what you would like.
To connect via Cygwin, follow this instruction https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/
After that you can be able submit in cygwin terminal your tasks for FPGA like: qsub -l nodes=1:arria10:ppn=2 job.sh
https://devcloud.intel.com/oneapi/documentation/job-submission/
Katerina
Thank You for Your reply! I have already done the steps described there and everything works) I meant that when I follow instruction from here https://devcloud.intel.com/oneapi/get_started/opencl/ ...
... I can not get X2Go because when I go to https://wiki.x2go.org/doku.php/download:start the link "mswin" does not start download. How can I get it? (I need to run GUI based applications such as Quartus and Modelsim, so I need to get X2Go as I understand).
Katerina
GRN2
I can suggest you VS Code DevCloud Connector that can automatically connect to DevCloud compute nodes including FPGA Arria10/Stratix10 and FPGA compile nodes:
https://marketplace.visualstudio.com/items?itemName=intel-corporation.vscode-oneapi-devcloud-connector
