Hi
Using vtune web interface on DevCloud, when I enable "Collect C-State events", I get the following error:
Sorry for not updating the topic. In fact, the error was due to incorrect user group assignment. The problem is now solved. Thanks.
Could you please let us know
- The analysis type you are trying to run in Vtune.
- Vtune version
- A sample reproducer of the input.
- Additional settings(if any) to reproduce the issue
Note: Below are the available analysis types in VTune
performance-snapshot
hotspots
anomaly-detection
memory-consumption
uarch-exploration
memory-access
threading
hpc-performance
io
gpu-offload
gpu-hotspots
fpga-interaction
system-overview
graphics-rendering
platform-profiler
tsx-exploration
tsx-hotspots
sgx-hotspots
hotspots-0
hotspots-1
As I said that problem exists on DevCloud. Now I am using my own Linux system and see the same error. So, let me explain what is my configuration.
I followed the steps here to change the ownership of /sys/kernel/debug/tracing
$ sudo chown -R mahmood:vtune /sys/kernel/debug/tracing
$ sudo ls -l /sys/kernel/debug/
total 0
drwxr-xr-x 2 root root 0 Mar 14 13:09 sync
drwx------ 8 mahmood vtune 0 Mar 14 13:09 tracing
drwxr-xr-x 2 root root 0 Mar 14 13:09 ttm
$ groups
mahmood adm cdrom sudo dip plugdev lpadmin lxd sambashare libvirt vtune
$ whoami
mahmood
So, all are set.
But as you can see below, when I launch vtune and enable "Collect C-State events", I still get the same error.
I would like to test the matrix multiplication example and the CPU is Intel(R) Core(TM) i5-6600.
We are unable to reproduce the issue from our end. Could you please share with us the exact steps you have followed. Let us know how you enabled the collect c-state event.
Remya Premdas
We haven't received any response from your end. Is your issue resolved?
Remya Premdas
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
